my shifter dropped. argh
Old May 3, 2005 | 04:52 PM
ironchef25's Avatar
Default my shifter dropped. argh
ok my shifter dropped. seems part ten is all torn up so the shifter dropped. where can i get this part 10. have you guys experience this.
Old May 3, 2005 | 04:56 PM
kulangot's Avatar
Default Re: my shifter dropped. argh (ironchef25)
sounds like #17 didnot get put back in...
CRX90ZCT's Avatar
go to http://www.hondaautomotiveparts.com or the honda dealership and they'll can get it for you
Old May 3, 2005 | 05:08 PM
ILLCRXSI's Avatar
i would also say that it sounds like #17 is what's wrong. you better get underneath the car and take a look before you start to order stuff.
Old May 3, 2005 | 05:11 PM
ironchef25's Avatar
Default Re: (ILLCRXSI)
no seventeen is intack. its the shifter it self. like when you sit in the car. you can pull it up and it will go up. then when you let go. it just settles in on a peice of metal. sorry thats what i meant by dropped. seventeen is still intack and good.
Old May 3, 2005 | 05:12 PM
ironchef25's Avatar
Default Re: (ironchef25)
13 bar doesnt move its the shifter it self that goes up and down.
Old May 3, 2005 | 05:17 PM
lodo1's Avatar
13 is just the stabalizer bar, its just there to hold the shifter up.
Old May 3, 2005 | 05:24 PM
ILLCRXSI's Avatar
maybe it's 16 then. i thought 10 was just a dust boot, but then again i can't really remember because i haven't had my shifter out in a long time.
Old May 3, 2005 | 05:42 PM
2fast4udude's Avatar
Default Re: my shifter dropped. argh (sirq2u)
agreed. my part 10 is half melted (never let two n00bs install a short throw ) and it works fine.. just gets dirty and messy to use quick
Old May 3, 2005 | 05:47 PM
ironchef25's Avatar
Default Re: my shifter dropped. argh (2fast4udude)
i think the part ten goes at the ball part of the shifter. it keeps it floating in the middle. with out it. it will just drop down
Old May 3, 2005 | 05:56 PM
ILLCRXSI's Avatar
i just checked majestic honda and their part description for #10 is a dust seal
Old May 3, 2005 | 06:02 PM
jurenic's Avatar
OMG, I had the SAME problem few weeks ago. You just need to go to Honda dealer, ask them to run a search on the part to see what dealer has one in stock, go and pick it up. If you can wait, order one.
It's pretty simple to replace it. Unbolt the shifter / linkage (One bolt holding it) remove old parts, or if they're not there just replace with new. For me it was just that cup, and that rubber peice that goes underneath it.
Old May 3, 2005 | 06:41 PM
ironchef25's Avatar
Default Re: (jurenic)
is it part 10?cause i think its that
Old May 3, 2005 | 06:58 PM
jurenic's Avatar
No, for me it was part 7. It's just a plastic "Cup" It probobly just got torn apart and fell off, cause I didn't find one when I was replacing it.
I believe it could only be:
Part 8 (Rare)
Part 10 (Probobly not, cause it's rubber)
Part 7 (Most likely)
Old May 3, 2005 | 07:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILLCRXSI &raquo;</TD></TR><TR><TD CLASS="quote">i just checked majestic honda and their part description for #10 is a dust seal</TD></TR></TABLE>
thats right, its just a dust/dirt seal.. its a boot
Old May 3, 2005 | 10:19 PM
ex voto's Avatar
Default Re: (2fast4udude)
#8 was my problem at one point. I just put it in wrong... I was tired.
Old May 4, 2005 | 12:30 AM
Dankz_Luke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">ok my shifter dropped. seems part ten is all torn up so the shifter dropped. where can i get this part 10. have you guys experience this.
****, pick it back up... Put some bolts in it.... i got like 3 a dem, JDM ones too
Old May 4, 2005 | 06:26 AM
ironchef25's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jurenic &raquo;</TD></TR><TR><TD CLASS="quote">No, for me it was part 7. It's just a plastic "Cup" It probobly just got torn apart and fell off, cause I didn't find one when I was replacing it.
Part 8 (Rare)
Part 7 (Most likely)</TD></TR></TABLE>
ok i check it and i dont have 7(must have fallen off). and 10 is all torn appart.
does anyone have a picture to how its assembled. like what goes bellow the ball and whats goes above. like does 7 go bellow the ball or above.
Old May 4, 2005 | 06:39 AM
ironchef25's Avatar
hmmm. another question. does part ten wrap around teh ball?
Old May 4, 2005 | 07:45 AM
part 10 goes around the ball
Old May 4, 2005 | 08:15 AM
ironchef25's Avatar
what about 7? does that go bellow the ball? so ten goes around the ball right ok got it.
Old May 4, 2005 | 01:23 PM
7 goes around the top of 10 i believe.. i'd have to get underneath again to look, but i'm pretty sure
Old May 4, 2005 | 02:57 PM
ILLCRXSI's Avatar
7 goes around the ball and 10 goes around 7
Old May 4, 2005 | 03:26 PM
ironchef25's Avatar
just making sure. the ball is underneath part 8 right? just making sure.
will teh dealer have these part?
Boostn B20
Jul 12, 2011 07:35 PM
casmello
Jan 12, 2005 06:25 PM
slash00R
Nov 1, 2004 07:23 PM
95GS-Racin
Dec 24, 2002 06:44 PM
caslmenow
Sep 7, 2002 08:39 AM
