My Brake rotors going the right way? Help!
Old May 3, 2005 | 02:28 PM
clizoman's Avatar
Default My Brake rotors going the right way? Help!
hey guys, i dont know if i put the correct sides on for my new brembo brake rotors. My rotors are acutally from my old 99' GS-R, but i guess they fit on my EP3 civic. although the caliper is on the rear on the EP should my rotor's veins go this way? or the other? tell me if i did it wrong or not....
Old May 3, 2005 | 03:51 PM
01-0720's Avatar
Default Re: My Brake rotors going the right way? Help! (clizoman)
unfortunitly you did it wrong
Old May 3, 2005 | 04:39 PM
3vilMonkey!'s Avatar
Default Re: My Brake rotors going the right way? Help! (01-0720)
yep... wrong
Old May 3, 2005 | 09:23 PM
adrian1281's Avatar
Default Re: My Brake rotors going the right way? Help! (3vilMonkey!)
i think he did it right.
and from here http://www.coximport.com/brembo/faq.html i give you this:
"Which direction should the discs rotate?
It is a popular misconception that the slots or drillings in a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation. There are three vane types in use:
Straight
Pillar vane (comprised of many small posts)
Curved vane
The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. Please see figure. Orienting the disc in the manner creates a centrifugal pump. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc's ability to dissipate heat.
Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure."
the last paragraph is the one that applies to you. so in your picture, the wheel is spinning clockwise when in forward motion. and the outer edge of the slot will contact the pad first. so in my opinion, yes, you did it right.
Old May 4, 2005 | 07:50 AM
EgRedSi's Avatar
Wrong
Old May 4, 2005 | 10:04 AM
adrian1281's Avatar
Default Re: My Brake rotors going the right way? Help! (EgRedSi)
please explain why it is wrong.
Old May 4, 2005 | 11:18 AM
jimmyjames's Avatar
They are mounted correctly. http://www.stoptech.com/faq/data/faq16.html
Old May 4, 2005 | 02:58 PM
k20whitevic's Avatar
Default Re: (jimmyjames)
Look good to me.
Old May 4, 2005 | 03:54 PM
Revolution2zz's Avatar
Default Re: (k20whitevic)
Yep, you did it right. The slots are suppose to face forward.
Old May 4, 2005 | 04:08 PM
Rtype16's Avatar
Default Re: (Revolution2zz)
In some cases the slots would be going the other way. However for Brembos you are going the right way.
Old May 4, 2005 | 04:29 PM
civiccpedx's Avatar
look wrong to me..... i have brembos and mine are on different.
Old May 4, 2005 | 07:04 PM
d.n.d.'s Avatar
wow some say right some say wrong... dunno me i cant tell thought usually it wouldnt matter which way (guess i was wrong )
Old May 4, 2005 | 07:10 PM
jimmyjames's Avatar
Default Re: My Brake rotors going the right way? Help! (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">look wrong to me..... i have brembos and mine are on different.</TD></TR></TABLE>
Yours are on wrong then. The OPs are the correct direction.
Old Jul 7, 2005 | 05:59 PM
migs's Avatar
Default Re: My Brake rotors going the right way? Help! (jimmyjames)
Need to see inside of the rotor. That can be right or wrong.
Old Jul 8, 2005 | 12:14 PM
menkio's Avatar
Default Re: My Brake rotors going the right way? Help! (migs)
roflo... IT DOES NOT MATTER
Old Jul 10, 2005 | 10:31 AM
xbn83's Avatar
Default Re: My Brake rotors going the right way? Help! (menkio)
It is RIGHT. I have Brembo drilled rotors, the instruction says the holes near the edge of the rotor suppose to touch the brake pad first. You did it right. Don't listen to MORONS. Tell them to kiss your a$$.
Old Jul 10, 2005 | 10:33 AM
xbn83's Avatar
kevinm1981
Aug 3, 2009 02:24 PM
Donboss
Nov 20, 2007 03:13 PM
gogordo
Sep 27, 2004 07:31 PM
PinchE NegRo
Mar 3, 2003 07:13 PM
Propulsion
Apr 8, 2002 07:21 AM
