d157-mini-me into 99ex...plz help
Old May 3, 2005 | 12:53 PM
e2000's Avatar
Default d157-mini-me into 99ex...plz help
I using the d15b7 block with the 99 complete head and manifold and dissy and the p2p ecu, and the 99 wiring harness, problem is the that the 99 block has the (CPS) crank position sensor, and this d15b7 does not have one from what I seen...will my car start up? If not what do i have to do so, I still have the 99y8 block in my yard but it useless.(spun bearing). plz I need this car..its sucks being on foot!
Old May 3, 2005 | 02:47 PM
e2000's Avatar
ttt
Old May 3, 2005 | 03:51 PM
Otherguy's Avatar
NASIOC.com
Default Re: d157-mini-me into 99ex...plz help (e2000)
i didnt use it but then again ur car is OBD2b i think
Old May 3, 2005 | 04:05 PM
e2000's Avatar
yea it's obd2b, I just wonder if it going to turn on.
Old May 3, 2005 | 04:07 PM
WildPig's Avatar
Default Re: d157-mini-me into 99ex...plz help (Otherguy)
Damn
I'm not sure about your situation but my suggestion is doing a obd2b to obd1 conversion so you dont have to worry about that sensor and will probably save you a lot of headaches.
Old May 3, 2005 | 04:22 PM
e2000's Avatar
ttt
Old May 4, 2005 | 04:47 PM
Otherguy's Avatar
NASIOC.com
Default Re: (e2000)
thats what i would do =\
Old May 4, 2005 | 05:08 PM
BauleyCivic's Avatar
Risky Business
Default Re: (Otherguy)
Crank position sensor is in the distributor buddy...
I think you're thinking of the knock sensor...
Old May 4, 2005 | 06:48 PM
e2000's Avatar
Its not the CPS I was mistaken it was the CKF or is it CFK...crank flu. sensor by the lower timing cover..only on obd2 cars..
Si Shane
Aug 2, 2005 05:41 AM
KingElli
Jun 14, 2005 08:07 AM
98civic94gsr
Dec 19, 2004 11:50 AM
Plan B
Nov 10, 2003 07:51 AM
