Stock CX hatch turns off mysteriously.
Old May 3, 2005 | 11:02 AM
EG_Civic_Si's Avatar
Default Stock CX hatch turns off mysteriously.
Last night i was driving home on highway 50. as i was merging onto highway 80, theres this bend in the road i love flying around, well halfway through it my car bounced a lil bit from the cracks in the road and SHUT OFF ! now im still in the turn doing about 80 MPH. I simply put the clutch in and started the car.
Looked at my friend like...wtf !? we stopped got out and checked the battery cables, they're fine. So we started back on the freeway, right before the exit we needed to get off on, which is another fun bend in the road, my car shuts off again ! this time i was doing about 90mph.
What could it be if its not the battery or battery cables? Is my engine just finally dieing becuz i beat the crap out of it everyday?
Old May 3, 2005 | 11:08 AM
TeamNextGenChris's Avatar
Default Re: Stock CX hatch turns off mysteriously. (EG_Civic_GSR)
were you low on fuel?possibly sloshing the fuel away from the pickup.
does the car lose electrical power,or does just the engine die?
Chris
Discosteak's Avatar
electrical portion of the ignition switch
Old May 3, 2005 | 11:10 AM
Default Re: Stock CX hatch turns off mysteriously. (BADEG4)
3/4 tank of gas. not sure if it keeps all the power. My deck doesnt work anyways, so i cant tell by that. My headlights stayed on, my gauge lights stayed on.
Old May 3, 2005 | 11:42 AM
GeorgeJetson's Avatar
Main Relay
Fuse box under hood.
Alternator
Those are things I have had problems with in the same category as your car
Old May 3, 2005 | 12:48 PM
Default Re: Stock CX hatch turns off mysteriously. (georgejetson)
I checked all my fuses, they are all fine.
As for the relay and alternator, I dont know how to check them besides taking it off the car and going to autozone.
Old May 3, 2005 | 01:10 PM
Not the fuses but the whole box
Also could be a ground
Old May 4, 2005 | 09:28 PM
Discosteak's Avatar
i can bet you its the electrical portion of the igniton swich
Old May 4, 2005 | 11:18 PM
eg6r4eva's Avatar
check the alternater housing. it might need to be replaced mine did that right after i got a full tune up. And it turned out it was that
Old May 6, 2005 | 09:55 AM
Default Re: Stock CX hatch turns off mysteriously. (eg6r4eva)
thanx all. I figured ill just do a B20/GSR swap to solve my problem
Old May 6, 2005 | 12:37 PM
Discosteak's Avatar
DUDE its not the engine that is the problem why wont you listen to me its the electrical portion of your ignition swich its going to do the same thing after you do the swap that it did before
Old May 6, 2005 | 12:49 PM
EE_Chris's Avatar
BADEG4 is probably right on the money. You know there was a recall for a lot of 96-00 hatchbacks for the ignition switch, right? For this EXACT same thing...
Old May 6, 2005 | 08:22 PM
Discosteak's Avatar
Default Re: Stock CX hatch turns off mysteriously. (EE_Chris)
THANK YOU at least someone realizes im not just blowing smoke out my ***
Old May 6, 2005 | 08:33 PM
Mario.'s Avatar
So wait, installing my turbo won't fix the problem? Wow... car modding scene sucks!
Costco
17
May 22, 2009 07:04 AM
buddy190
Feb 4, 2009 03:34 PM
R015
Dec 15, 2008 03:36 PM
jdmvtecej2
Aug 8, 2008 11:52 AM
93eg2james
Nov 7, 2006 04:09 PM
