who use brass fittings Straight on the turbo?
Old May 3, 2005 | 09:22 AM
RACEPAK's Avatar
Default who use brass fittings Straight on the turbo?
as topic says
is it safe?
thanx
Old May 3, 2005 | 10:24 AM
Muckman's Avatar
Moderator in Chief
Default Re: who use brass fittings Straight on the turbo? (RACEPAK)
why wouldnt it be safe?
brass is recommended bc its soft and is less likely to mess up your threads.
Old May 3, 2005 | 12:15 PM
Tactic$'s Avatar
Default Re: who use brass fittings Straight on the turbo? (Muckman)
what size should the nipple be?? (for vaccum to WG) I have to go buy one of these today....
Old May 3, 2005 | 12:20 PM
dustin's Avatar
Default Re: who use brass fittings Straight on the turbo? (Tactic$)
1/8" NPT
But you'd be better off plugging that port and running the vacuum to the intake manifold.
Intercoolers cool air, so they drop the volume of the air, so pressure drops across them.
Wideopentuning's Avatar
1/8 npt thread usually with a 3/16 barb .
Old May 3, 2005 | 12:25 PM
EJ1 wilcox's Avatar
Default Re: who use brass fittings Straight on the turbo? (Wideopentuning)
I'm using straight brass fittings for my coolant lines... works fine.
I've seen them used for both oil and coolant, so I don't think you will have a problem.
Rubixcu7
Jul 11, 2005 08:27 PM
Krayzielix
Jun 17, 2004 03:42 AM
Talon12bp
Nov 27, 2003 07:45 AM
JDMCRX
Aug 22, 2003 08:14 AM
boosted_zc
Jul 13, 2003 09:02 PM
