what does a pinion gear do? and where is it located.....
Old Feb 2, 2002 | 01:16 PM
Pinhead's Avatar
New User
Default what does a pinion gear do? and where is it located.....
here's the deal I've had ALL the bearings replaced in my transmission and it still makes these two DISTINCT noises
noise #1-a grinding/churning noise while in neutral with foot OFF the clutch...gets louder as a rev the engine...
noise #2-a loud high pitched whining that gets louder at higher rpm's/speeds in ANY gear....but as soon as I press the clutch the sound is gone....also if i hold down the clutch and put it in other gears it makes the whine sound fora split second when I slam it into the gear...keep in mind the gear is just rolling at 45-50mph with the clutch still in...
P.S. nosie is coming from the tranny on the side where the gears are...also reverse is sometimes a bitch to get into
could it be a pinion gear??? i have NO clue what it is....I've brought it in and replaced all my bearings and it obviously wasn't that
[Modified by typerman1358, 10:17 PM 2/2/2002]
Old Feb 2, 2002 | 01:44 PM
D's Avatar
D
Default Re: what does a pinion gear do? and where is it located..... (typerman1358)
have you checked your muffler bearing yet?
Old Feb 2, 2002 | 01:46 PM
Pinhead's Avatar
New User
Default Re: what does a pinion gear do? and where is it located..... (D)
no where is a muffler bearing.....explain where it is and what it does D
Old Feb 2, 2002 | 01:47 PM
AssPenny's Avatar
You got robed on bearings my main man.
Old Feb 2, 2002 | 01:48 PM
Pinhead's Avatar
New User
Default Re: what does a pinion gear do? and where is it located..... (AssPenny)
I replaced my mainshaft bearing my two driveshaft bearings my throwout bearing and my input shaft bearing....I think that's it...not sure though....I put my car on a lift and spun the tires and the noise was coming from where the gears are in my tranny
[Modified by typerman1358, 10:49 PM 2/2/2002]
Old Feb 2, 2002 | 01:49 PM
D's Avatar
D
like i said before, i don't think it's necessarily anything in the tranny..... and if it were your bearings, and you paid someone $100 to replace them, i highly doubt the work was even considered...
just turn up the damn radio. and get all those fuggin gay parts off your car..
D
AssPenny's Avatar
You replaced them or you got somebody to replace them for you?
I think you got robed on bearings my main man.
Old Feb 2, 2002 | 01:50 PM
Pinhead's Avatar
New User
I paid him 325 to replace them..he charged me 200 the first time...and then since it wasn't fixed he only charged me 125 to drop the tranny a 2nd time...I was there when he replaced the gears
Old Feb 2, 2002 | 01:53 PM
D's Avatar
D
well, then there's nothing wrong with your tranny then. look elsewhere to diagnose said sounds.
oh, TAKE THAT DAMN FIRE EXTINGUISHER OFF THE PASSENGER SIDE A PILLAR!!!!!!!!!!!!!!!!!!!!!!!
D
Old Feb 2, 2002 | 01:55 PM
AssPenny's Avatar
Perhaps you have a broken clutch or pressure plate. U still using stock?
[Modified by AssPenny, 2:55 PM 2/2/2002]
Old Feb 2, 2002 | 01:56 PM
Pinhead's Avatar
New User
I am I am damn D.....lol oh and D I have been takin from the darkside and to the all motor side
I am ordering some parts for my car and I have already sold my direct port nitrous system all thanks to these all motor guys...tired of worrying about my motor I want reliable power all the time I'm taking my car to this guy Dwayne at honda monday to check out the sound.....we'll see what he says
Old Feb 2, 2002 | 01:57 PM
Pinhead's Avatar
New User
nope running with ACT xtreme plate and street disc
Old Feb 2, 2002 | 01:58 PM
AssPenny's Avatar
I've been told that ACT clutchs are only good up to 8000 rpm, perhaps it the bed on you.
[Modified by AssPenny, 2:59 PM 2/2/2002]
Old Feb 2, 2002 | 01:59 PM
Pinhead's Avatar
New User
lol I hope not....I'll check that as well though...but I have no problems getting into gear...except for reverse sometimes hehe....oh and PS....the noise is coming from the complete opposite side of the tranny so pretty sure it's not the clutch heheeh
[Modified by typerman1358, 11:03 PM 2/2/2002]
Old Feb 2, 2002 | 03:04 PM
Mr. Softee's Avatar
i had the same problem. check your spark plug fluid... somehow mine was mixing with coolant and causing overuse of the clutch.
HondaLuv3r4Life
Transmission & Drivetrain
Dec 11, 2013 09:24 AM
OneFire
Aug 7, 2009 04:24 PM
itsLOUiSduh
Mar 9, 2009 08:35 PM
TiredToyotaDriver
Jan 14, 2006 07:26 PM
Pinhead
Feb 4, 2002 12:37 PM
