Need quick help on removing upper A-arm
Old Feb 2, 2002 | 11:25 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Need quick help on removing upper A-arm
I'm in the process of switching my upper A-arm to the Skunk2 camber kit. How do I separate the ball joint on the stock A-arm from the connecting steel piece? I removed the pin and the pin nut already. How do I pull the upper arm out?
Do I need a ball joint separator tool? I don't have one. What are the other options?
Thanks!
Old Feb 2, 2002 | 02:11 PM
D's Avatar
D
Default Re: Need quick help on removing upper A-arm (Wai)
take a hammer, and hit the steering knuckle on the side just below the ball joint. now, there's not a lot of room in there, and it's kinda tough to get it right, but if you still have a load on the steering knuckle, it will pop out. oh, and try not to hit the threads
D
Old Feb 2, 2002 | 03:04 PM
Wai's Avatar
Wai
Default Re: Need quick help on removing upper A-arm (D)
Thanks for the info D.
I ended up getting a small gear puller (2 claws), and the ball joint shot right out....! Scary, I thought I broke something.
djnikko
Jun 11, 2010 10:19 AM
HKSuperSi
Suspension & Brakes
15
Feb 12, 2008 08:49 PM
russianswty
Feb 18, 2007 02:24 PM
ice11honda
Aug 30, 2004 05:50 PM
BigD+Itsuki
Jun 24, 2002 10:50 AM
