Cluster needle removal
Old May 2, 2005 | 04:24 PM
queensny's Avatar
Default Cluster needle removal
Whats up fellas, hoping to get some good feedback, I am working on a project that involves my cluster on my acura CL. I seen later model integra's and appear to have the same cluster needle set up. I would like to know the exact most PROPER method of removing the needles. after some research on HT, it appears that it is really a matter of prying them open by pullin up EVENLY. is this so?? what tools if any?
Old May 2, 2005 | 05:20 PM
orangebarius's Avatar
Default Re: Cluster needle removal (queensny)
use ur hands. they do come off with a little bit of force. if u need to use a flat head screwdriver, just be careful.
Old May 3, 2005 | 11:39 AM
queensny's Avatar
Default Re: Cluster needle removal (orangebarius)
This is relief. I just wanted to make sure.. I plan on using one of those miniture flat haed screw-drivers that are used on watches and glasses etc.. any other handy advice is greatly apprecited..
Old May 3, 2005 | 11:46 AM
be.twenty's Avatar
yup.. just pull off.. straight up and you're good..
Old May 3, 2005 | 01:14 PM
SonicBlueTeg's Avatar
i hope u have some way of recalibrating the needles to their proper place.. once u pull off the needles they just dont go right back on and read properly..
recalibrating the needles usually needs some type of computer(laptop/pda) with the proper software program and a way to hook it up so the car and computer can "talk" to each other..
Old May 3, 2005 | 04:26 PM
queensny's Avatar
Default Re: Cluster needle removal (SonicBlueTeg)
My project involves transfering 97cl gauges that are now BLACK to 97CL guages in WHITE "both stock". I was told about "flexing" them over the needle but I think this might cause a crease or permanent dent. Has you heard of this method? And is there really risk to cause a crease?
Thanks agian,, what ever feedback helps..
Old May 5, 2005 | 12:34 PM
queensny's Avatar
The problem is honda paints the back of the CL guages durring the factory process. THe paint they use makes my acura CL cluster glow with a PUKE GREEN color, nasty! i plan on stipping that color off with alot of care and hopfully make them glow "white" vs green.. However I want to carefully remove the guages without haveing to recalibrate the obdomiters,, any secrets to achiving this? advice?
Old May 5, 2005 | 04:33 PM
queensny's Avatar
anyone??
g0tVTEC
May 13, 2006 02:35 PM
Sliced Beard
Aug 28, 2004 03:03 PM
TegLover4life
Apr 19, 2003 12:38 AM
bgod
Dec 17, 2002 12:12 PM
bgod
Dec 17, 2002 10:53 AM
