TPS SENSOR PROBLEMS
Old May 2, 2005 | 04:09 PM
shivern's Avatar
Default TPS SENSOR PROBLEMS
Ok when i was replacing the clutch i roped up the engine, and without looking i tightened it and broke the damn tps sensor off, now i have another one, and i had to replace the rivet screws with real screws to make life 10x easier.. now its all replaced and i reset the ecu... STILL code 7? WTF! m8? anyone help?
Old May 2, 2005 | 04:15 PM
shivern's Avatar
Default Re: TPS SENSOR PROBLEMS (shivern)
pleasee
Old May 2, 2005 | 04:32 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Well, you don't just bolt it and drive away.
It has to be set back to OEM specs. This is how you do it. You will need a multy tester/ meter and set it to volts DC with a range no greater than 5 volts. Don't worry about the range if you can't adjust that.
Now, cut a small window on the insulation at the middle wire at the TPS plug.
loosen the screws a bit.
turn the ign. key to II ( you should see all the dash lights come on, but don't start the engine )
Put the + lead of the meter at the middle wire on the TPS plug where you cut the window.
Put the - lead of the meter on a good engine ground.
Now adjust the TPS so it reads close to .45 volts at idle. Don't move the throttle .
Once you have it there, tighten the screws and double check that the voltage didn't change when you tightened the screws.
That should do it.
Modified by The new Spaceballs at 7:42 PM 5/2/2005
Old May 2, 2005 | 04:41 PM
Mach69's Avatar
Default Re: TPS SENSOR PROBLEMS (The new Spaceballs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs &raquo;</TD></TR><TR><TD CLASS="quote">Now adjust the TPS so it reads close to 4.5 volts at idle. </TD></TR></TABLE>
I think you mean 0.5 Volts at idle and 4.5V at WOT.
Old May 2, 2005 | 06:41 PM
No Big Whoop
Default Re: TPS SENSOR PROBLEMS (Mach69)
Yeap that was a typo. I set them to .45 volts, not 4.5 volts.
Thanks for catching that.
Old May 2, 2005 | 06:52 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs &raquo;</TD></TR><TR><TD CLASS="quote">Yeap that was a typo. I set them to .45 volts, not 4.5 volts.
Thanks for catching that.</TD></TR></TABLE>
Just trying to help felow honda-techer's out.
turbo-crx
Oct 1, 2011 10:24 AM
cranker
Jul 15, 2010 03:22 PM
jfruauff
10
May 3, 2008 11:41 PM
all_motor
Feb 14, 2005 09:52 PM
Morhpeous
May 24, 2004 07:00 PM
