93 CIVIC AUTO/MANUAL
i would like to put a obd1 ls motor in my civic......unfourtately, my car is auto.....how do i convert it and does anyone know what all i'm looking to spend.....SERIOUSLY>????
Thanx in advance.....
make sure you get a 5 spd tranny w/ mount when you buy your swap.
I have the clutch pedal and clutch line and clutch master cylinder (whatever you call it) you will need.
It is a really easy swap, you'll need all your clutch stuff(listed above) and custom tranny mount which hasport has of course the shift linkage and axles. Wiring is reverse light, vtec, (maybe) and make sure you take out the piece connected to the shifter in park so you can take your key out. If you need this in more depth use the search I did my whole swap that way, It has all your answers
First thing id spend on is some TIME with the search button. Seriously tho this has been covered a ton, theres even some picture tutorials on how to do it somewhere but since you wont look neither will I.
AznInvasion
Sep 12, 2003 06:19 PM
