TRANS HELP
Old May 2, 2005 | 12:45 PM
killerDelSlo's Avatar
Default TRANS HELP
ok my girl friend has a 93 del sol. She just got a new paint job and body kit.(typical girl car). But n e way when she has it in neutral and has the clutch in and starts coming to a stop ther is a loud weeeeeeeeeeew noise, kinda like the power anttenae motor when u turn the car on, but the thing is it doesnt happen all the time and its very random at the moment. the clutch is new and i have no idea wut could be making the noise. Any expertise would be helpful im not familiar with imports.thanks.
Old May 2, 2005 | 12:55 PM
Bond's Avatar
Default Re: TRANS HELP (killerDelSlo)
Throwout bearing? Thats my guess. Did you replace it with the clutch? A worn throwout bearing caused my tranny to do a "wooshing" noise and not all the time too. I just dropped my tranny and the throwout bearing is really bad.
Old May 2, 2005 | 01:01 PM
Default Re: TRANS HELP (Bond)
thats exactly what i was thinking. im not sure if it was replaced when the clutch was replaced. How expensive is that too fix and is it a diy?
Old May 3, 2005 | 11:53 AM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerDelSlo &raquo;</TD></TR><TR><TD CLASS="quote">thats exactly what i was thinking. im not sure if it was replaced when the clutch was replaced. How expensive is that too fix and is it a diy?
It is a DIY if you have the skill to remove the tranny. Not hard at all. I just dropped my tranny and the throwout bearing is trashed. doesn't even spin. Eat up my press. plate real nice. Went through about half way on the press. plate. While your in there if you do the work replace the pilot bearing too. I popped mine out and the bearing is real loose and worn. If the clutch was just done, most of the time the clutch kit comes with a new throwout bearing. It is just standard to replace it when in there.
Old May 3, 2005 | 07:27 PM
Right, but nm that, she said its when its in first gear coming to a stop not neutral!
Old May 3, 2005 | 08:22 PM
EJ8VTEC's Avatar
Mr. Indecisive
possibly the main shaft berring, thats how mine sounds in all gears while the rpms r dropping
Vt3c_eg
Apr 28, 2008 11:31 AM
jimbrown
Jul 17, 2007 12:35 PM
vlc92189
Jul 23, 2006 05:01 PM
AJxr
21
Jan 11, 2006 03:21 PM
idriveadelsol7
Aug 25, 2005 03:44 PM
