fuel pump change
Old May 2, 2005 | 12:42 PM
IntegraRacer17's Avatar
Default fuel pump change
I've got a 90 teg hatch.. do i have to drop my tank to change my fuel pump? How would i go about doing this?
Old May 2, 2005 | 12:47 PM
CalGSR99's Avatar
Default Re: fuel pump change (IntegraRacer17)
remove your back seats to expose the gas tank cover. From there you can remove the pipe connections and 12 mm bolts holding the cover on.
Old May 2, 2005 | 01:05 PM
Default Re: fuel pump change (CalGSR99)
when I remove my back seat all I can see once the cover is taken off, is the top of a electrical connector, there are no little bolts in sight. unless you have to take off another cover that is attached to the tank and underneath the connector. Now if I am correct there is two conectors under your back seat. The one above all covers which is for the fuel pump.. and one that is under the circle cover for the fuel level. IF this is the case...and please correct me if i'm wrong. I would have to drop my tank then. This is how I understand what is there, can anyone confirm what i believe?
Old May 2, 2005 | 01:10 PM
CalGSR99's Avatar
Humm... once you remove the back seats you should see something like this. But then again this is for an 99 integra, i just thought it would have similar steps.
Here is the actual how to for the picture above.
http://www.c-speedracing.com/h...p.php
Old May 2, 2005 | 01:16 PM
it's similar above although there is a spot where i can disconnect those wires, but once that cover is off there isn't any nuts or natta only another electrical connector that isn't part of the same lines going through that cover.
Old May 2, 2005 | 01:32 PM
iakona's Avatar
nope. it's like the accords, i think you have to drop the tank. that's what i remember from flipping through my helms anyways. that cover is for the sending unit.
but it's only a 10 gallon tank, not like the 14 gallon accord tank...
Old May 2, 2005 | 01:36 PM
Default Re: (iakona)
is there anyway i can drop the tank without removing the gas, and without needing an afternoon to do it?
Old May 2, 2005 | 03:52 PM
93aztecgreenGSR's Avatar
just drive your car until your low fuel light come on. then raise your car up and drop the tank. thats how i put my 255 in.
Old May 2, 2005 | 03:56 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
good info, i'll be changing mine in the near future
Old May 2, 2005 | 05:21 PM
Default Re: (93aztecgreenGSR)
thanks for the help and the tips, i will be putting my 255 in as soon as my gas guage gets low.
90 ef
Dec 2, 2009 05:33 PM
Mike1486
Sep 24, 2004 11:19 AM
B20LS-T
Aug 16, 2003 10:56 PM
SpeedMonkeyRacing
Nov 29, 2002 06:08 AM
pelotudo
13
Sep 2, 2002 11:02 PM
