b16 knock sensor
Old May 2, 2005 | 10:42 AM
tc_gts's Avatar
Default b16 knock sensor
my buddies ef b16a keeps throwing a code 23 for knock sensor...
-we have replaced sensor
-placed new wire to computer..
checked for ground...
and it still throwing a code any help please
Old May 2, 2005 | 10:49 AM
EP3_05's Avatar
Default Re: b16 knock sensor (tc_gts)
Are you sure the knock sensor is wired to the correct pin on the ecu?
Old May 2, 2005 | 02:17 PM
Rywire's Avatar
Default Re: b16 knock sensor (91civic)
that, and try a new ecu
Old May 2, 2005 | 06:10 PM
Colt Seavers's Avatar
What ecu are running?
Old May 2, 2005 | 07:21 PM
Super79Dave's Avatar
Here's a thought maybe the sensors working and is sensing a knock in the motor or something banging against the motor or too much vibration.
you can test a knock sensor buy hooking up your dvom to it a hitting the block with a hammer i suggest testing at the ecu to rule out the wiring in between
Old May 3, 2005 | 08:57 AM
tc_gts's Avatar
Default Re: b16 knock sensor (Super79Dave)
well...im pretty sure its a pr3 but if its not its pwo, its my buddies car so im not sure.. The knock sensor has ground we have check that and we have put new wire and tried no knock sensor now i think he didnt use insolated wire could ahve be it?
Old May 3, 2005 | 09:03 AM
kylefakesi-r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tc_gts &raquo;</TD></TR><TR><TD CLASS="quote"> i think he didnt use insolated wire could ahve be it?</TD></TR></TABLE>
loosely translates to "i don't think he used an insulated wire-could that be the problem?"
yes...always use insulated wire unless you like electrical problems and fires.
Old May 3, 2005 | 10:54 AM
Outsane's Avatar
Default Re: b16 knock sensor (kylefakesi-r)
I think the insulated he means is like the O2 sensor where there is a grounding sheath around the normal insulation.
but I could be wrong
Old May 3, 2005 | 01:15 PM
tc_gts's Avatar
Default Re: b16 knock sensor (Outsane)
thats exactly the type of wire it uses I did my swap with that type of wire but my buddy is an idiot and doesnt wait for me to help him lolz
Old May 3, 2005 | 07:23 PM
tc_gts's Avatar
bumpity
Old May 3, 2005 | 11:44 PM
Rywire's Avatar
are you sayin that your groundin the knock sensor?? The KS is a 1 terminal plug, make sure your pin is on the top side of the plug, and its pinned correct in the plug. Dont externallty ground it, its only 1 wire to the ecu, B19.
Ryan
Old May 4, 2005 | 05:26 AM
tc_gts's Avatar
Default Re: b16 knock sensor (droppedcrxsi)
ya i know its one wire.. and its grounds to the block... i donno im just trying to get some ideas so i when i go to his house ill know what to go looking for but thanks
crxb16ftw
May 20, 2007 10:31 PM
95redeg6
Apr 28, 2007 10:23 AM
Grnade
May 2, 2005 08:45 PM
ddong2lee
Mar 4, 2004 05:06 AM
EF_LSVtec
Apr 10, 2003 11:25 AM
