SQUICKY CLUTCH
Old May 1, 2005 | 10:54 PM
numero sete's Avatar
Default SQUICKY CLUTCH
hey guys i know ima newbie from MTL but i have a question, it might have already happened to some of you...
most often then not when i press my clutch all the way in it squicks everytime. At first it was tolerable but now it annoys me alot!
I wanted to know if a nice shot of WD40 would help me out but then again a clutch is not something you want to get slippery!
ANy ideas?
Old May 2, 2005 | 05:19 AM
RusBear's Avatar
Default Re: SQUICKY CLUTCH (numero sete)
Yeah, same problem here... a shot of WD-40 at the point where the shaft connects to the pedal cures the problem temporarily, but I would like to know if anybody has found a better solution.
Old May 2, 2005 | 07:12 AM
StRacer's Avatar
Default Re: SQUICKY CLUTCH (RusBear)
Yea, mine does it too. I know its not the slave cylinder by the engine. I imagine some type of grease would work. Back me up for type to use.
Old May 2, 2005 | 07:23 AM
KSE's Avatar
KSE
mines does only when its cold. goes away completely after a few minutes of driving.
Old May 2, 2005 | 08:26 AM
Jimmy's Avatar
Global Moderator
My pedal has just started making a noise too!
TTT!
Old May 2, 2005 | 08:31 AM
CRXified's Avatar
Default Re: (Jimmy)
mines squeeks too, did it before my swap and now after my b16 swap so im guessing its something on the petal where it attaches to teh clutch MS. maybe a loose bolt or something?
Old May 2, 2005 | 08:48 AM
MonkeyMagic's Avatar
Default Re: (CRXified)
a thin coating of grease right inbetween where the head of the slave cylinder's pushrod and the arm of the clutch release fork meets.
Old May 2, 2005 | 03:51 PM
thanks for the great replies
im looking into your comments right away!
thank you
Old May 2, 2005 | 03:56 PM
fastrunner's Avatar
for those that have the problem when its cold its because there is a rubber cap over hole where the piston goes into the master cylinder. If you pop the cap off put some grease behind it then put it back on you will be set.
Old May 2, 2005 | 03:59 PM
JDM Vision's Avatar
Default Re: SQUICKY CLUTCH (KSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KSE &raquo;</TD></TR><TR><TD CLASS="quote">mines does only when its cold. goes away completely after a few minutes of driving.</TD></TR></TABLE>
Old May 9, 2005 | 11:46 AM
Jimmy's Avatar
Global Moderator
Default Re: (MonkeyMagic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic &raquo;</TD></TR><TR><TD CLASS="quote">a thin coating of grease right inbetween where the head of the slave cylinder's pushrod and the arm of the clutch release fork meets.</TD></TR></TABLE>
Picture?
In the engine bay.. the black boot that covers that i guess i would think it would be the slave cylinder?
I'm lost
Old May 9, 2005 | 04:26 PM
CRXified's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
Picture?
I'm lost
correct under the boot is slave cyclinder
Old May 9, 2005 | 04:36 PM
s2kkk's Avatar
Its the fork at the tranny. Look at the tranny where you bleed the clutch. Take the rubber boot off and have someone rapidly push the clutch in and spray WD-40 or PB Blaster inside the tranny where the boot covers.
Old May 9, 2005 | 07:33 PM
CRXified's Avatar
Default Re: (spoon.eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon.eg &raquo;</TD></TR><TR><TD CLASS="quote">Its the fork at the tranny. Look at the tranny where you bleed the clutch. Take the rubber boot off and have someone rapidly push the clutch in and spray WD-40 or PB Blaster inside the tranny where the boot covers. </TD></TR></TABLE>
isnt the boot there to stop **** from going in there? is it alright to spray **** in there and it wont damage the slave cyclinder?
Old May 9, 2005 | 08:40 PM
nalinc23's Avatar
If you use WD40 it will work for a week or so then come back, mine squeaks too, i think it's something you have to deal with. Just make sure you put the dustcap/bootie back on the clutch assembly when you're done.
Old May 9, 2005 | 09:57 PM
JDMKid71's Avatar
Default Re: (Jimmy)
Sounds like everyone’s confused to me... my car does the same thing... i think mine however is coming directly from the pressure plate when i press the petal. .. However... the thing under the dash , the part that the petal connects to is the Clutch Master Cylinder (you can see the other half mounted to the firewall in the engine bay), the part that bolts to the tranny and is black and moves the release fork in the tranny bell housing is the Clutch Slave Cylinder.
The squeaks could be coming from the petal it self, the master cly., the slave cly., where the slave cly. and release fork meet, or the pressure plate, or perhaps even where the release fork and throw-out bearing meet. hope this cleared up most of it. and Correct me if im wrong please.. Thanks
Old May 9, 2005 | 10:07 PM
Bond's Avatar
Default Re: (JDMKid71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMKid71 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like everyone’s confused to me... my car does the same thing... i think mine however is coming directly from the pressure plate when i press the petal. .. However... the thing under the dash , the part that the petal connects to is the Clutch Master Cylinder (you can see the other half mounted to the firewall in the engine bay), the part that bolts to the tranny and is black and moves the release fork in the tranny bell housing is the Clutch Slave Cylinder.
I sure hope it's not your throwout bearing, press. plate, or slave cylinder. If it is then you got some bigger problems than you think. I bet it's your master cylinder push rod. It's inside and connects right to the pedal.
Old May 9, 2005 | 10:31 PM
JDMKid71's Avatar
Default Re: (Bond)
Nope just replaced my master cly. its in the press plate.. lol i know i have problems i think its squeaking from the clutch getting over heated due to its been slipping for the past.... 3 weeks.. haha im replacing the press plate, clutch, flywheel and both bearings this upcoming weekend however... so well find out what the prob is... ill also never seize where the slave pushrod meets the release fork so ill know that’s not squeaking...
Old May 9, 2005 | 11:01 PM
jerbear!'s Avatar
same. but also if u can hear a rattle sound while ur foot is off the clutch, then it would be the throw out bearing. to fix that just lube it up!
Old May 9, 2005 | 11:33 PM
Bond's Avatar
Don't spary it in the tranny. You will put grease on the clutch and flywheel. Just put it on the slave cylinder end and on the fork.
Old May 10, 2005 | 02:50 AM
jerbear!'s Avatar
o no nonono i didnt mean spray it in the tranny, i was talking about when the tranny makes a rattling sound. but when the squeaky sound comes then just lube up the release fork
Old May 15, 2005 | 10:48 AM
Jimmy's Avatar
Global Moderator
I went to advanced auto parts and bought some automotive grease in a spray can.. took the boot off barely shot any on the fork and then rubbed it around.. my problems fixed.
thanks yO!
Old May 22, 2005 | 11:57 PM
s2kkk's Avatar
I'm kinda late on this. But.... use PB Blaster. Works way better than WD40.
91ACCORD4GLX
Mar 23, 2013 07:46 AM
Tman6925
Apr 19, 2012 11:34 PM
hmongshaa
Honda Civic (2001 - 2005)
13
Apr 10, 2007 12:43 AM
PoWeRBaN_PaNdA
Nov 29, 2005 05:10 PM
Erik_Pb_Foot
Sep 9, 2001 10:58 PM
