Check engine in 5th gear!
Old May 1, 2005 | 09:28 PM
97dc2's Avatar
Default Check engine in 5th gear!
Whenever i go into vtec in 5th gear i get a code 22. What could it be? The only thing that i can think of is my oil pump because sometimes when im in vtec at about 6500-7000 my car kind of bogs and it sounds like the oil pump is spuddering
Old May 1, 2005 | 09:56 PM
Miz101's Avatar
Default Re: Check engine in 5th gear! (97dc2)
Taken from ECU code thread... code #22 is VTEC pressure valve. Hope that helps you solve your issue a little better.
Old May 1, 2005 | 10:51 PM
pbizzlegsr's Avatar
mine does the same thing..every gears vtec is fine..redline every gear koo except 5th. is your oil pan dented?
Old May 2, 2005 | 07:56 AM
97dc2's Avatar
Default Re: (Palmy Blue)
No my oil light does not come on. And i think my oil pan does have a dent in it. Ill check today.
fer
Oct 20, 2017 01:40 PM
jsar92
16
Jul 16, 2010 04:40 PM
hotdoggies
Apr 11, 2005 04:25 AM
pbizzlegsr
Oct 27, 2004 01:39 PM
UpstateCivic
May 10, 2003 05:18 PM
