DA sway bar choices?
I'm currently running a Sus Tech 19mm (I believe) on my DA and I want something bigger. I have been kinda looking but are there any other options for say a 22mm bar?
Not sure what's out there but I got something a little larger than a 22mm. ..like 10mm larger
Too bad it's not in production
Modified by emissionsux at 10:40 PM 5/1/2005
Modified by emissionsux at 10:13 AM 5/2/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emissionsux »</TD></TR><TR><TD CLASS="quote">
How'd you get the exhaust past that thing?
</TD></TR></TABLE>How'd you get the exhaust past that thing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">
How'd you get the exhaust past that thing? </TD></TR></TABLE>
cant u see the exhaust stopping right before the bar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boma23 »</TD></TR><TR><TD CLASS="quote">not bein funny but is there any give in that at all?
or does the inside wheel just lift straight from the off?
It's hollow and hollow bars aren't the same in stiffness as a solid bar. So a 32mm hollow bar isn't anywhere near as stiff as a 32mm solid bar. You can't really compare it to a solid bar unless you know the torsional rates of both. Length and wall thickness of the bar all count too, as does how long the arms are.
</TD></TR></TABLE>It's hollow and hollow bars aren't the same in stiffness as a solid bar. So a 32mm hollow bar isn't anywhere near as stiff as a 32mm solid bar. You can't really compare it to a solid bar unless you know the torsional rates of both. Length and wall thickness of the bar all count too, as does how long the arms are.
didn't realise that people used hollow bars (although the thought did occur to me when 32mm was mentioned
wouldn't a walled tube give more opportunity for fatigue and deformation? (although if the guy's got the figures to show it's 1520% over standard, I'm sure he knows his materials too
and is that a bush or a bearing?
)wouldn't a walled tube give more opportunity for fatigue and deformation? (although if the guy's got the figures to show it's 1520% over standard, I'm sure he knows his materials too
)and is that a bush or a bearing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boma23 »</TD></TR><TR><TD CLASS="quote">wouldn't a walled tube give more opportunity for fatigue and deformation? </TD></TR></TABLE>
Actually it doesn't . If you look at the stressed areas of a solid bar when torsional load is applied, most of it is to the outside of the bar, this is the same as a hollow bar. The inside of the solid bar gives it a little bit more rigidity and strength, but not as much as you'd think. This is why you can have a hollow bar that is only 10mm larger in OD, but has a thin wall and is a higher torsional rate. Pound for pound a hollow bar will always be stronger than a solid bar (torsionally).
BTW: this info is from a book called "engineer to Win" by Caroll Smith. good reading if you want to know why parts break and how to make parts that don't break.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boma23 »</TD></TR><TR><TD CLASS="quote">and is that a bush or a bearing?</TD></TR></TABLE>
I'm not 100% sure but it looks like a bearing.
thanks, never thought of it that way - always good to learn (i never got to uni)
out of interest, what's the diameter of the (Uk 1.6i 16v) EF's OEM anti-roll bar? Is it identical to the DA6? or thinner or fatter (hopefully!)?
