Some ?? Bout 1gen b16
Old May 1, 2005 | 03:55 PM
Ekay Jay's Avatar
Default Some ?? Bout 1gen b16
Iv been planning on doing a ls-vtec in my 93 DA for a while now. Heres my setup:
Sir 1 pr3 b16a head
pr3 pistons + oem rings
chipped p28
Golden eagle lsvtec kit
GSR water + oil pump
GSR timing belt
ARP rod bolts
ARP head studs
ITR 4-1 header
My ?? is..What kind of wiring am i suppose ta run for the vtec solenoid? Since this head is obd-0 and my car is obd-1, Is there anything this will conflict with the head... Like the fuel injectors? Can i use the b16 injectors with my ls harness?
Old May 1, 2005 | 04:09 PM
JDMDB2's Avatar
Default Re: Some ?? Bout 1gen b16 (JdM DA InTeGrA)
You will need to use an obd1 distributor, obd1 injectors (your LS ones will work just fine) and an obd0 Vtec plug, other than that, everything will work. You can just use a different style plug for the vtec soloniod but you will need both male and female ends. Run the wires for Vtec soloniod and Vtec oil pressure switch.
Old May 2, 2005 | 08:01 AM
Ekay Jay's Avatar
Default Re: Some ?? Bout 1gen b16 (JDMDB2)
Can i use my ls dizzy?
Old May 2, 2005 | 02:10 PM
Ekay Jay's Avatar
Old May 2, 2005 | 06:26 PM
Ekay Jay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA &raquo;</TD></TR><TR><TD CLASS="quote">Can i use my ls dizzy?</TD></TR></TABLE>
Old May 3, 2005 | 08:53 AM
Ekay Jay's Avatar
BUMP cuz i need to know
Old May 9, 2005 | 04:56 PM
Ekay Jay's Avatar
Old May 9, 2005 | 09:05 PM
riceball777's Avatar
non vtec and vtec distrubitors have different bolt patterns
the only way to use a ls dizzy is to cut one of the legs off and only 1 of the 3 holes will line up
Old May 10, 2005 | 07:56 AM
Ekay Jay's Avatar
Default Re: Some ?? Bout 1gen b16 (riceball777)
Then what dizzy can i use that will bolt up?
Old May 15, 2005 | 04:54 PM
Ekay Jay's Avatar
Also this head will come with a 0bd-0 vtec selenoid, Will it work properly with my setup?
Old May 16, 2005 | 08:55 AM
Ekay Jay's Avatar
Old May 16, 2005 | 06:06 PM
Ekay Jay's Avatar
up
Old May 16, 2005 | 06:30 PM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA &raquo;</TD></TR><TR><TD CLASS="quote">Then what dizzy can i use that will bolt up?</TD></TR></TABLE>
use an obd1 vtec distributor
Old May 16, 2005 | 07:02 PM
Ekay Jay's Avatar
Default Re: Some ?? Bout 1gen b16 (DA9-hari)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9-hari &raquo;</TD></TR><TR><TD CLASS="quote">use an obd1 vtec distributor</TD></TR></TABLE>
Like????
Old May 16, 2005 | 09:23 PM
HARI.'s Avatar
from an obd1 b16 or a gsr
Old May 17, 2005 | 04:04 AM
Ekay Jay's Avatar
Default Re: (Palmy Blue)
Y would i have ta cut off one leg? cant i just not bolt that one leg up? Also what about my vtec selenoid, Will an obd-0 selenoid work ok?
Old May 17, 2005 | 05:18 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (JdM DA InTeGrA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA &raquo;</TD></TR><TR><TD CLASS="quote">Y would i have ta cut off one leg? cant i just not bolt that one leg up? Also what about my vtec selenoid, Will an obd-0 selenoid work ok?</TD></TR></TABLE>
That One leg is the one that gets in way of the vtec solenoid.
Old May 17, 2005 | 06:52 AM
Ekay Jay's Avatar
Default Re: (FlatBlackTeg)
thx for the info guys . But what about my vtec selenoid?
Old May 17, 2005 | 09:06 AM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA &raquo;</TD></TR><TR><TD CLASS="quote">thx for the info guys . But what about my vtec selenoid?</TD></TR></TABLE>
yeah your obdo vtec solenoid will work fine
Old May 17, 2005 | 09:37 AM
AIminiS10's Avatar
You will just have to hard wire it. It will work fine, just like the other folks have said.
Old May 17, 2005 | 09:59 AM
Ekay Jay's Avatar
Default Re: (AIminiS10)
Thx alot guys
eg6d15
Dec 31, 2007 08:40 AM
Novtecdohc
10
Jan 25, 2006 07:34 PM
dropped like its hot
Apr 24, 2005 02:58 PM
elrandeeto
Nov 25, 2004 04:08 PM
Absentmind
Jun 17, 2004 09:52 PM
