Suspension & Brakes Theory, alignment, spring rates....
another sway bar question
Old May 1, 2005 | 03:16 PM
MAD GSR's Avatar
Default another sway bar question
i just installed an itr sway bar on my gsr and made my own reinforcement kit that i made from looking at the bsq kit deminsions. so i took of the bolts that hold up the abs lines and used one of the holes that the abs line bolted up to. i used spacers so that it mounts up there stragiht and a thick *** plate that the d brackets are mounted flush against for support. i just used the top stock sway bar hole and just a longer 10mm bolt in the abs hole and it works great so far, and seems like it would be strong. just wondering what yall think and if anybody has used this same exact meathod of mounting the bar up there.... dont want to rip my subframe!!!
Old May 1, 2005 | 05:13 PM
graham8's Avatar
Default Re: another sway bar question (MAD GSR)
Well that sounds exacly like the BSQ kit (which I just installed tonight) ... so I'd say you are set.
Old May 1, 2005 | 05:38 PM
MAD GSR's Avatar
Default Re: another sway bar question (graham8)
you used a longer 10mm bolt in the far left abs hole right?
Old May 2, 2005 | 06:33 PM
MAD GSR's Avatar
bump
MAD GSR's Avatar
bump
Old May 15, 2005 | 03:54 PM
graham8's Avatar
hey sorry ... yes I used a longer 10mm bolt that I got from honda ... if you go to BSQ's page, it shows you exactly what bolt & nut to buy.
G
Groove_D
Suspension & Brakes
Mar 20, 2007 06:29 PM
Bigmojoj27
Nov 28, 2006 10:11 PM
spog
Oct 12, 2004 01:23 PM
skunkintegra
May 2, 2003 03:31 PM
grngsr01
Apr 22, 2003 09:35 PM
