Jdm integra gauges?
I just recently bought a honda integra typeR cluster and the fuel gauge works as in it moves but it doesnt actually measure my actual fuel. So what can I do to fix it? I have a 96 gsr and the gauges came out of a 00' type R. Does a type r have the same fuel tank capacity as well?
Modified by tannerhoops at 2:44 PM 5/1/2005
Modified by tannerhoops at 2:46 PM 5/1/2005
Changing the needle may royally screw up ur good gauge too. afaik the needles don't like to be moved on the gas gauge so you have to be careful. I changed one on my old cluster and they would never be in the correct position no matter what i tried.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99LStegra »</TD></TR><TR><TD CLASS="quote">jut a quick question not stealing the thread.... but how do u read the kilometer spedo on the jdm guages?</TD></TR></TABLE>
i use my eyes usually.
I swear to God, do you people never search??? Replace the plastic film on the back of the ITR cluster with the film from the original cluster out of your car and it works just fine and dandy.
And regarding reading in kilometers. Every 25 kph is about equal to 15 mph.
How do you replace the plastic film if you can't take off the needle? I'm not that damn stupid I've already thought of that. I wouldve tried that but it would brake the needle if youve ever looked at the gauge. If the needle wouldnt have popped off I wouldve definitly done that.
Modified by tannerhoops at 5:15 PM 5/2/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">I swear to God, do you people never search??? Replace the plastic film on the back of the ITR cluster with the film from the original cluster out of your car and it works just fine and dandy.
And regarding reading in kilometers. Every 25 kph is about equal to 15 mph.</TD></TR></TABLE>
maybe you should read alittle more before being a dick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerhoops »</TD></TR><TR><TD CLASS="quote">How do you replace the plastic film if you can't take off the needle? I'm not that damn stupid I've already thought of that. I wouldve tried that but it would brake the needle if youve ever looked at the gauge. If the needle wouldnt have popped off I wouldve definitly done that.
Modified by tannerhoops at 5:15 PM 5/2/2005</TD></TR></TABLE>
film = green circuit board film on back of the cluster
I thought if you have a 94-97 teg you want to use the 96 spec type r gauge and it you have a 98-01 teg you want to use the 98 spec type r gauge to have it work right????question really...could be wrong
1mile=1.62km
so, just divide everything you see on you km/hr cluster by 1.5 since it's easier than 1.6. then add back a few. or just take your calculator and do some divisions, and use a cheat-sheet for a while stickied to your dash. when you don't need it any more, then you can take a friend for a ride
