will not rev past 5k
Old May 1, 2005 | 09:07 AM
mr. carpenter's Avatar
Default will not rev past 5k
i'm about to burn this car. i spun a rod bearing on my motor at the track. i put in a new z6 motor, y8 manifold, and lightweight flywheel. i've gone through all i can think of and nothing has changed. the car runs great it just will not rev past 5k. i tried to post in the eg forum but appearantly if you have an ef you can't post in there. this is driving me nuts. i swapped vtec solenoids. went back to the a6 injectors and resistor box. car drives and shifts smoothly so i do not think it's anything to do with the flywheel. would incorrect cooling routing cause it? i believe the lines are on right but need to recheck. i've been searching for two weeks and can't find anything related this. help me. here are some recent threads i've created that give more info on the setup.
https://honda-tech.com/zerothread?id=1231033
https://honda-tech.com/zerothread?id=1223676
https://honda-tech.com/zerothread?id=1222701
Old May 1, 2005 | 12:16 PM
Default Re: will not rev past 5k (mr. carpenter)
ttt
Old May 1, 2005 | 04:01 PM
DOHClessEF-9's Avatar
im having the same problem but with a sohc non v, but i think its cuz i have a p28 but going vtec soon the thing just bogs when it reaches 5g
hayes
Feb 28, 2009 11:38 AM
TallKyle
Jul 4, 2006 11:25 AM
Big O
Dec 17, 2004 12:49 PM
hontegra
32
Dec 1, 2003 07:15 AM
