Crank pulley?
Old May 1, 2005 | 08:28 AM
civiccoupe94's Avatar
Default Crank pulley?
im about to do a t-belt and water pump change, and i got a B15b7. i took off the a/c systerm and have no powersteering, which means im only running the alternator belt.
my crank pulley has slots for the alternator belt and the a/c belt, and im wondering where can i buy a crank pulley with only 1 slot for the alternator belt, but not a underdrive pulley. i heard stories bout not having enough charge witht the underdrive..
Old May 1, 2005 | 08:30 AM
oh yea im doing this because the cam gears cost like 100 bucks.. want to make my engine a tad bit faster and save more gas
Old May 1, 2005 | 08:33 AM
egsleepercivic's Avatar
take your oem pulley to a machine shop get the ps and ac portions of the pulley machined off then have them balance it.
Old May 1, 2005 | 08:43 AM
how much would that cost? other than that option, does anyone know a place i can get a aftermarket lighter crank pulley? i dont want to use my old one cause its a bit rusted so i guess its better off putting a new lighter one since its going to come off for the t-belt
Old May 1, 2005 | 09:19 AM
mr. carpenter's Avatar
Default Re: (civiccoupe94)
d15b7 correct? it would cost you a little bit but the 4th gen std pulley is quiet a bit lighter and has the alternator splines and one other set. the thing is you'd have to use a fourth gen alternator because it's a different belt.
Old May 1, 2005 | 10:37 AM
to get a pulley machined and balanced I would say no more than fifty......most aftermarket pulleys don't have a dampner which keeps you from ruining your bottem end
tolowhb
Sep 20, 2009 10:18 AM
bow tie
Oct 17, 2008 01:18 PM
saveacivic
Nov 23, 2005 11:19 AM
TeamTooQuick
Sep 11, 2003 09:52 PM
