99 Si Cluster Interchangable?
Old Apr 30, 2005 | 08:35 PM
whiskaz's Avatar
Default 99 Si Cluster Interchangable?
searched but the thread i found wasnt that clear if it is plug and play or not... but i was just wondering if they are plug and play..if not does anyone have rewiring diagram b/c i got a good deal on the clusters thanks
Old Apr 30, 2005 | 08:37 PM
civictildeath's Avatar
Default Re: 99 Si Cluster Interchangable? (whiskaz)
https://honda-tech.com/zerothread?id=1024818
Old Apr 30, 2005 | 08:59 PM
SOHC4life 96's Avatar
Default Re: 99 Si Cluster Interchangable? (civictildeath)
Interchangable between what cars? If you are talking about 96-00 civics then yes. If you are talking about putting it into a pre-96 civic then you will have to rewire it. If it is a pre-96 then basically, get the plugs from a 96-00 civic, then cut yours off and color match.
Old Apr 30, 2005 | 09:10 PM
whiskaz's Avatar
Default Re: 99 Si Cluster Interchangable? (SOHC4life 96)
92-95 civic.. what you mean cut the plugs and color match? the colors are the same?
Old Apr 30, 2005 | 09:11 PM
komat's Avatar
most of the wires should be the same
do a search or look at the faq for the wiring chart
SchematicCivic
Jan 21, 2016 11:04 AM
hb_guy
Dec 19, 2005 12:59 PM
xkwzt21
Nov 16, 2004 07:51 AM
pezzy
Jul 4, 2004 07:06 PM
vtecjj
Jan 15, 2003 10:00 PM
