Squeeking sign whenever i push down on my clutch
I have a 96 Honda Accord 4 door LX sedan. The car is stick shift, whenever i push down on the clutch i hear a squeaking sound. does anyone know what that means?
Check to see if the clutch master cylinder is leaking by looking for leakage around the rubber boot underside of the dash.
If not that, then it is probably just the spring making noise, some lubricant would work.
if squeak is from under dash it is the spring like accord94 said ,if it is coming from under hood it could be that your cluch gearing is dry ,pull the boot back at tranny where clutch slave cylinder is spray some lube grease , wd40 works also inside there it helps if someone can activate clutch pedal while you spray .........at times you got no choise but to replace bearing
JSIR
May 2, 2005 01:14 PM
SAPPHIREblue6SPEED
Sep 13, 2003 12:25 AM
