type r lip install???
Old Apr 30, 2005 | 01:55 PM
veilsides2000's Avatar
Default type r lip install???
anybody have any links to how to install a type r lip. the reason im asking this is because i have one but it doesnt quite seem right. and i also want to know where to install the screws. because when i install it the middle part is lifted up a little bit.im sorry if you guys have trouble understanding this. its the best way i could descrid\be it
Old Apr 30, 2005 | 02:05 PM
AlxSiR7's Avatar
Default Re: type r lip install??? (veilsides2000)
jdm or usdm front? on my jdm lip its just two screws (1 in each wheel well) and i used little zip ties to hold it to the bumper cover underneath.
Old Apr 30, 2005 | 02:07 PM
Default Re: type r lip install??? (AlxSiR7)
its a 98 usdm front. and a oem type r lip
Old Apr 30, 2005 | 02:10 PM
Dc4turbo408's Avatar
all u need is two screws. i have 98 front with type r lip. look at my pic.
Old Apr 30, 2005 | 02:13 PM
Johnytang's Avatar
Default Re:
yea all i put were the two screws on the sides.. i also put the 98+ type r lip on a 97 integra and we made it fit by cutting around the middle.. depending on the qual of the lip
you might have to modify it a bit... but putting it on the 2000gsr fit just fine
Old Apr 30, 2005 | 02:21 PM
Backk InTheDA's Avatar
I hate everything
When i went to fit a iTR lip on my 91 front end, had to bolt at the wheel wells, and under neath, looks good though.
Old Apr 30, 2005 | 04:06 PM
SonicBlueTeg's Avatar
the lip was not only for the type ro.. it is called an "oem optional lip"..
there is 1 phillips screw on either end of the bumper and a bracket that has 2 on the lip and one into the bumper on either end..(8 phillips screws)
and a bunch of other bolts that look like this...
i dont know what they are called but u slip the thingie with the threads onto the factory bumper so the bolt has something to go into..
hope that helps..
Old Apr 30, 2005 | 10:09 PM
stumpyf4's Avatar
Default Re: type r lip install??? (SonicBlueTeg)
Look here:
http://www.pbase.com/jw___syst...tions
Hdeucedeuce
Jul 25, 2010 04:27 PM
Budget Racer
27
Jun 18, 2007 08:46 AM
GS-Rcivic
Feb 2, 2003 05:55 AM
JDlvl InTEGRA
Jan 9, 2003 11:10 PM
lessthndan
Oct 8, 2002 08:27 PM
