gs-r head on b18LS?
Old Apr 30, 2005 | 08:41 AM
b18CivicEx's Avatar
Default gs-r head on b18LS?
would it be smart to put a gs-r head on a b18b1 LS? I hear you get really bad valve clearance if you do it. Positive feedback please.
Old Apr 30, 2005 | 09:07 AM
IggyBcool's Avatar
its just like every other ls vtec.......no with "bad valve clearance"i dunno. personally i wouldn't do a ls vtec. thats why i just got a gsr. im sure changing the head to any vtec head will hender the valve clearance...
Old Apr 30, 2005 | 10:04 AM
apok's Avatar
Default Re: (99LStegra)
The valve clearance will be fine with the LS pistons. If you change to really high-compression, you'll need to make sure they aren't flat or domed, though or you'll be tapping since the V-TEC lobe gives the valves more travel than an LS cam does.
I personally didn't do LS-VTEC because of cost and reliability. You need to buy a lot of things to make the hybrid work correctly, and you could have peace of mind by buying a GSR or B16 swap instead.
Old Apr 30, 2005 | 10:12 AM
tegsallgood's Avatar
Default Re: (apok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apok &raquo;</TD></TR><TR><TD CLASS="quote">The valve clearance will be fine with the LS pistons. If you change to really high-compression, you'll need to make sure they aren't flat or domed, though or you'll be tapping since the V-TEC lobe gives the valves more travel than an LS cam does.
I personally didn't do LS-VTEC because of cost and reliability. You need to buy a lot of things to make the hybrid work correctly, and you could have peace of mind by buying a GSR or B16 swap instead.</TD></TR></TABLE>
My LSvtec uses a GSR head. and to say an LSvtec isnt reliable is stupid. people always say that, and its just not true. if you can change a headgasket, you can mate a vtec head to a block. buy the GE conversion kit and your set. it really is such an easy swap. and just as reliable. i take mine to 8k fully tuned all day every single day, it holds oil like any other motor, never heats up. put down decent numbers too. i love it
Rrm101
Northeast (Sales)
14
Jun 27, 2009 05:25 PM
iKhmaiFoSho
Mar 17, 2008 02:45 AM
master honda tech
59
Jun 12, 2005 08:42 AM
tegracer94
Aug 24, 2004 01:38 AM
