Yupp, another help fix my damned mini-me thread
Old Apr 30, 2005 | 07:46 AM
Jowee's Avatar
Default Yupp, another help fix my damned mini-me thread
I got the bright idea to take out my perfectly fine JDM GSR and put a mini-me in my eg-->> https://honda-tech.com/zerothread?id=1220992 . I ended up using the LS harness I had on the GSR that was wired for VTEC.
ECU:
It started up fine on the first try then I realized it was running on my chipped JDM GSR ECU and swapped it out with a stock P28. The P28 immediately threw a code and started to cause it to idle surge. When I tried to jump the code, the CEL just stays on and doesn't blink. I then plugged in a USDM P72 and the CEL went away and it idled fine so I kept it in there for the time being.
Driving:
I'm not sure if VTEC is engaging, but I'm almost positive it's not. Drivng on the streets it's fine, but if I try to hold the RPM at 3500-4000 RPM in 1st and 2nd gear it sputters/boggs/backfires a little. Once I hit about 50-60mph the CEL pops on . When I try to jump the code with the car on, nothing happens. When I turn the car off, it goes away. And when I leave it in gear and am cruising regardless what gear and let off the gas pedal, it just slows down like usual then a second later jumps.
Gas mileage is REALLY crappy too. 1/2 a tank got me 50 miles
Help is greatly appreciated guys.
EDIT: Ended up cleaning my IACV and changing the IAT sensor. I went back to the P28 also.
Modified by ITR 98 1162 at 10:27 AM 5/3/2005
Old Apr 30, 2005 | 08:06 AM
egsleepercivic's Avatar
put the gsr back in that will most likely fix your issue, solid cel means bad ecu
Old Apr 30, 2005 | 08:10 AM
LShatchie's Avatar
Default Re: Yupp, another help fix my damned mini-me thread (ITR 98 1162)
I would use the p28 and try to figure out why the idle is surging, on my LS swap it ended up being the tps sensor needed to be adjusted, not the fiac or whatever that everyone usually has the problem with.
Modified by LShatchie at 1:20 PM 4/30/2005
Old Apr 30, 2005 | 08:30 AM
how do you adjust the map, do you mean tps?
Old Apr 30, 2005 | 09:19 AM
LShatchie's Avatar
Default Re: (egsleepercivic)
yeah sorry about that, tps not map lol
Old Apr 30, 2005 | 09:48 AM
Jowee's Avatar
Default Re: (LShatchie)
TPS is still originally calibrated. I'll try another P28 and cleaning the IACV.
Old Apr 30, 2005 | 10:14 AM
all8280bcc's Avatar
Default Re: (ITR 98 1162)
go back to the gsr.
Old Apr 30, 2005 | 12:05 PM
Cuong-nutz's Avatar
is the purge valve and IAT sensor wired up correctly? Sounds like ECU could be faulty.
Old Apr 30, 2005 | 02:24 PM
Jowee's Avatar
Default Re: (Cuong-nutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz &raquo;</TD></TR><TR><TD CLASS="quote">is the purge valve and IAT sensor wired up correctly? Sounds like ECU could be faulty.</TD></TR></TABLE>
Are they both 2 wire plugs? I know the red and green one is suppose to go to the IAT and that means the other goes to the purge valves?
Old Apr 30, 2005 | 02:50 PM
Cuong-nutz's Avatar
both are two wire plugs.
The IAT sensor is a green/white + red/yellow plug
The Purge vavle is a yellow/black + red
Old Apr 30, 2005 | 03:07 PM
Jowee's Avatar
Hrmm...what's the 1 wire plug that's similar to those.
Old Apr 30, 2005 | 03:13 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Not completely certain of the name, but the one wire sensor that I saw late lastnight went into block on the left hand side at the very top. Right under the head, is this the one you're talking about? Any other day I would go out and just look, but I don't want to look at my car right now. I'd also like to think you're bogging due to getting too much fuel. I don't think looking at the plugs is going to help much since you haven't been running on this long.
Old Apr 30, 2005 | 03:19 PM
LShatchie's Avatar
Default Re: (INVALID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID &raquo;</TD></TR><TR><TD CLASS="quote">Not completely certain of the name, but the one wire sensor that I saw late lastnight went into block on the left hand side at the very top. Right under the head, is this the one you're talking about? Any other day I would go out and just look, but I don't want to look at my car right now. I'd also like to think you're bogging due to getting too much fuel. I don't think looking at the plugs is going to help much since you haven't been running on this long. </TD></TR></TABLE>
I think your talking about the coolant temp. sensor on the back of the block like on my b18a block.
Old Apr 30, 2005 | 03:31 PM
Cuong-nutz's Avatar
I can't think of any other thing that is one wire except for that coolant temp sensor. Check to see if the color wires match up. What color is the one wire you have? Take some pictures of where the wires are coming from as well.
Old Apr 30, 2005 | 03:37 PM
LShatchie's Avatar
I was just thinking about it and yes that would make perfect sense, since he is using an LS wiring harness that has the coolant temp. sensor on the block, thats the exact area where it would be located, thats what that one wire plug is.. and the other 2 wire is in fact for the iat sensor.
Since you are not using a 92-95 civic wiring harness its not going to have the other 2 wire plug that looks similar to the iat that is for the purge valve or whatever... the ls harness doesnt have that plug.
Old Apr 30, 2005 | 03:44 PM
Cuong-nutz's Avatar
I wonder if he has hooked up the coolant temp plug to the sensor on the head under the dizzy.
Anyhow, it all makes sense now. Reason your idle is high is because of the purge valve. Get it hooked up and you'll be fine.
Old Apr 30, 2005 | 03:46 PM
Jowee's Avatar
IAT and purge:
Here's the extra plug that hangs by the knock sensor under the intake mani:
Coolant:
Old Apr 30, 2005 | 04:31 PM
LShatchie's Avatar
I have never seen that extra plug before.. what year LS harness is that?
Old Apr 30, 2005 | 04:52 PM
jarvis199's Avatar
get a d16z6 harness, itll make life easier in the long run, or get a d15b7 harness and cut the vtec plugs off the gsr harness u have and wire them up...
Old Apr 30, 2005 | 05:01 PM
Cuong-nutz's Avatar
do you remember what the single wire plug connected to on your gsr?
Old May 1, 2005 | 09:09 AM
Jowee's Avatar
It's an OBD I LS harness and I don't think that wire was ever attached to anything. I plugged back in a P28 last night and it threw an auto tranny code, so I'll rechip it tonight and an IAT code which I replaced with an extra I had laying around.
Thanks for the help guys
I hope the fuel consumption goes down.
Old May 1, 2005 | 10:23 AM
BoostinEJ1's Avatar
your being punished for replacing a b-series motor for a d-series motor by the h-t gods
god luck with figuring it out though
Old May 1, 2005 | 08:03 PM
ironcheftony's Avatar
that 1 wire plug that is red/blue is the knock sensor plug
Old May 3, 2005 | 07:43 AM
Jowee's Avatar
Default Re: (ironcheftony)
Thanks for the help guys.
Now I'm throwing a CEL 43. I changed out my 255 BBK fuel pump to an OEM ITR, but it still is throwing the code after 5 min of driving. Any ideas on how to diagnose which part of my fuel supply system is screwed up? My friend though my injectors looked kind of big, being that I have never had any SOHC experience they all look the same to me. Could these be B series injectors which is causing the code?
Old May 3, 2005 | 07:49 AM
Bserieskllr's Avatar
most bseries injectors are the same as the d-series except the itr which has bigger and i thin the y7 has 170cc but most are 240cc.
