Would you...obd2?
is converting my car to obd2 as easy as just swapping engine harnesses?
ie 92 d15b7 to 98 d16y7...
in other words...im getting the full harness and ecu from the bay to the ecu for nothing and was wondering if that is all i would need to convert it or is there more to it?
Would you convert?
Would you convert?
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Ok, what you are asking to do is somewhat complex. Do you have an OBD-II motor or something? If you have an OBD-II motor and your putting it in an OBD-I or OBD-0 car you would have to either make the engine harness clips that connect to the chassis harness the same OBD as the car, or you would have to make the chassis harness clips that connect to the engine harness the same ODB as the engine harness/engine. If you are using an OBD-II ECU in an OBD-I or 0 you would need a conversion there as well. Why exactly do you ask the question. Need it for funtionality, or just like the look of OBD-II clips?
lol like the looks?! Didn't know they HAD looks...lol
but to clear up the question better:
Im getting a y7 98 obd2 motor...my gf's dad and the guy at the yard said i should just convert it to obd2 since im getting the complete engine harness and ecu that would reach all the way down to the ecu...SO...would it be easier or harder to convert? Or should i just stay obd1 and reuse my b7 parts...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi »</TD></TR><TR><TD CLASS="quote">lol like the looks?! Didn't know they HAD looks...lol
Im getting a y7 98 obd2 motor...my gf's dad and the guy at the yard said i should just convert it to obd2 since im getting the complete engine harness and ecu that would reach all the way down to the ecu...SO...would it be easier or harder to convert? Or should i just stay obd1 and reuse my b7 parts...</TD></TR></TABLE> Ok this is what I would do. Figure out whick ECU is better. Take the clips from the dash harness for that ECU and splice them in. Then take the OBD-II clips from the chassis harness and replace the OBD-I clips on your car with them. This way if you decide to go B-seires later all you would need to do is buy an OBD-II motor. Even if you get another OBD-I you could always convert it back. SAVE THE LEFT OVER CLIPS!!!
LOL
LOL
there must be a diagram of something for this...i just dont want a headache with wiring issues...i'll have to wait and see the whole swap first before i decide...i thought just reusing the old b7 parts would be alot easier...
https://honda-tech.com/zerothread?id=550976
This is what you should do (By B18C5-EH2 the 6th post down). Search is your best friend.
thanks for the link! So i'd use my old b7 ecu and be alright then i guess since the y7 doesn't have vtec...interesting...i'll have to clear it up with him some or anyone else...
EDIT oh and i searched...but nothing pertaining this particular swap and didn't wanna GUESS that since they're swapping over with the B series, it should be the same with the D's.
white4doorsi
Mar 31, 2008 05:20 AM
INCNTRL4
Jan 4, 2006 12:58 AM
