B16a1 idle problem
I have a B16a1 in my CRX si 1991.
The problem is that im throwing code 23 (Knock-Sensor) and im having a terrible idle problem (fluctuates from 1k-200 RPM).
I just replaced the distributor and i notice my timing belt (tensioner) is a little loose, would that cause my idling problem??
fix your code first dude. the KS Code will throw some stuff off. Then check the TPS, and the IAVC and then make sure your throttle cable isn't kinked or bound up. Then make sure the idle screw isn't loose or too tight....But seriously check out that code. Try and clear the ecu first.
Behind the block on the towards the driver side, underneath the Intake manifold, there's a two prong clip. The sensor has a red and black wire coming off of the sensor. That's if the sensor was taken off the si-r harness.
chinese acrobat
35
Nov 1, 2009 12:00 PM
coot_er
Oct 1, 2005 09:58 AM
smokinsi
Jul 18, 2004 05:09 PM
