Mini me help numba 2
Old Apr 29, 2005 | 03:03 PM
Otherguy's Avatar
NASIOC.com
Default Mini me help numba 2
OK... my **** doesnt idle at all, what can i do to make the idle more steady... right now its just going up between 1000 and 600... and it sounds like its going to die =X
Old Apr 29, 2005 | 03:16 PM
WildPig's Avatar
Default Re: Mini me help numba 2 (Otherguy)
probably a vacuum leak, check your hoses .......
Old Apr 29, 2005 | 05:27 PM
Otherguy's Avatar
NASIOC.com
Default Re: Mini me help numba 2 (WildPig)
ok fixed... now im getting a cel still... rpm levels are good... its just now, every time i give the car gas, the MPH goes up.... when i put it in a gear the tires dont move =X pulled out an axle and there is this metal bar in between the shafts.. whats going on =X
Old Apr 29, 2005 | 05:35 PM
Otherguy's Avatar
NASIOC.com
bump
Old Apr 29, 2005 | 06:02 PM
civicboisi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">ok fixed... now im getting a cel still... rpm levels are good... its just now, every time i give the car gas, the MPH goes up.... when i put it in a gear the tires dont move =X pulled out an axle and there is this metal bar in between the shafts.. whats going on =X</TD></TR></TABLE>
if you put it in gear and ur wheels don't turn...you could have a frozen caliper or bad brake hose...try turning the rotor on the hub? Spin freely or stuck?
Explain the "metal bar" between the shafts thingy more...
Old Apr 29, 2005 | 08:59 PM
Otherguy's Avatar
NASIOC.com
Default Re: Mini me help numba 2 (civicboisi)
BUMP HELP
Old Apr 29, 2005 | 09:09 PM
SOHC4life 96's Avatar
The bar in the middle means it is not an LSD tranny. I wanna call it an open differential but I don't know if that's right.
Old Apr 29, 2005 | 09:14 PM
Otherguy's Avatar
NASIOC.com
Default Re: Mini me help numba 2 (SOHC4life 96)
do you have any pictures?
Old Apr 29, 2005 | 09:16 PM
Cuong-nutz's Avatar
clutch went out?? did you check to see if you have a frozen caliper? Please clarify what's wrong.
Old Apr 29, 2005 | 11:55 PM
Ignitecivic's Avatar
Default Re: Mini me help numba 2 (Cuong-nutz)
was the car fine when it was stock or it happen when u swap over the head?
Old Apr 30, 2005 | 03:04 AM
Otherguy's Avatar
NASIOC.com
Default Re: Mini me help numba 2 (Ignitecivic)
Ok... so i figured it out... it was really stupid... i was getting a CEL for 10 so i pulled the sensor out and i find that it had melted... great... so i dig around find another sensor and replace it... fine.. all good no cel anymore... Then i was wondering why my MPH were going up as i gave my car gas... Well my dumb *** forgot about the axle wasnt in on the passenger side... so yeah... after i got all that **** done and put my car back together i took her out and she blew my mind... she was pullin harder then my 96 ex swap... too bad gas was like 2.75 blarg.... anyways pictures will follow in another thread...
Uncle Ben's
15
May 15, 2010 07:54 PM
Radim
10
Aug 5, 2009 02:37 AM
Deano_D aka "Brick Top"
Dec 2, 2005 10:20 PM
IntegraLs94Cam
Dec 25, 2004 03:03 PM
jeff652
Jan 3, 2003 04:16 PM
