type r tach in ls or gsr cluster?
can the type r 10k tach work correctly with the gsr or ls guage clust if swapped out? also the speedometer also. any help would be appreciated thanks.
Yes, but the gauge faces won't match your stock gauge faces. Not only will they look different, but will light up different as well. Just buy a whole ITR cluster.
the thing is i cant do that, i have a civic running integra wiring. obd1 is differnt from obd2 wiring. so it wont work. and trust me it will light up the same. ahah but yeah, obd1 and obd2 wont work properly when swapped clusters.
Buy a whole ITR cluster, swap all the gauges into the OBD1 cluster housing, you have a nice cluster with matching gauge faces that works. Do that instead of buying just 1 gauge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You could always repin the OBD1 wiring to OBD2 cluster.</TD></TR></TABLE>
you just have to swap out the housing. easier
quaker
Aug 6, 2007 11:56 PM
HNP
Dec 22, 2006 03:36 PM
