Hasport Press Release
Old Apr 29, 2005 | 02:16 PM
brian g's Avatar
Default Hasport Press Release
Hasport would like to announce the release of the new EKK2 mount kit. This kit is designed to be use with the EG crossmember, steering rack and lower control arm. This allows the engine to be mounted rearward another 2 inches and up about an inch. This ideal for drag racing as it straightens the axles and road racing becuase it moves engine weight rearwards.
The kit has two sets of mounting holes so that the engine can be mounted slightly lower so that the P/S pump can be used without modifying the hood. Even with the engine mounted in this lower position because the oilpan is so close to the front wheels ground clearance is still excellent.
brian g
Old Apr 29, 2005 | 05:58 PM
Turbogixxer's Avatar
Default Re: Hasport Press Release (brian g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g &raquo;</TD></TR><TR><TD CLASS="quote">This allows the engine to be mounted rearward another 2 inches and up about an inch. </TD></TR></TABLE>
Any clearance issues with header(s)? That is a bit of a move back.
Old Apr 29, 2005 | 07:31 PM
Lenthrax's Avatar
Default Re: Hasport Press Release (Turbogixxer)
is the EG crossmember direct fit onto Ek's?
Old Apr 29, 2005 | 08:41 PM
locash's Avatar
No issues at all, the header fits fine.
Old Apr 29, 2005 | 08:42 PM
locash's Avatar
Default Re: Hasport Press Release (Lenthrax Performance)
The EG crossmember fits fine as well, provided you also use the EG steering rack and lower control arms.
Old Apr 29, 2005 | 09:55 PM
FULLTHROTTLE's Avatar
Default Re: Hasport Press Release (locash)
How much room does it leave for a turbo back there?
Old Apr 30, 2005 | 02:36 PM
keithg's Avatar
Default Re: Hasport Press Release (suprfast)
Some pics here: https://honda-tech.com/zerothread?id=1213376
Old Apr 30, 2005 | 04:43 PM
bossman032's Avatar
I have the first gen mounts what different??
Turbo clearance was pretty good on the old one.
new one 2" backward why??
Old May 1, 2005 | 03:13 PM
keithg's Avatar
Default Re: Hasport Press Release (bossman032)
More engine set-back has better weight distribution for road racing. The EKK2 kit does not replace the EKK1 kit, it is merely an alternative.
GBRacing
34
Feb 3, 2010 12:03 AM
dropped like its hott
May 26, 2007 09:56 AM
Tyson
13
Dec 24, 2003 10:25 PM
blazinb16
Apr 25, 2003 11:28 AM
lilcasino
Dec 29, 2002 03:25 PM
