Engine Dampner Kit
Old Dec 29, 2002 | 11:09 AM
lilcasino's Avatar
Default Engine Dampner Kit
Does anyone have any info on J's Racing Engine Dampner Kit? I remember a pic of one installed awhile back. If my memory is correct it bolts up to the drivers side engine mount.
Old Dec 29, 2002 | 01:49 PM
Big Phat R's Avatar
Default Re: Engine Dampner Kit (lilcasino)
According to A&J racing - they don't fit LHD cars properly.
Use stiffer motor mounts instead - probably cheaper too.
Old Dec 29, 2002 | 02:16 PM
RagingAngel's Avatar
Default Re: Engine Dampner Kit (Big Phat R)
BPR is right.... the J's mount will only work for 6th gen Civics...as the USDM DC2s have the master cylinder conveniently mounted smack dab in the way.....
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Engine Dampner Kit (RagingAngel)
This one?
https://honda-tech.com/zerothread?id=359126
[edit] Never mind. I can't read. [/edit]
[Modified by Splat, 6:17 PM 12/29/2002]
Old Dec 29, 2002 | 02:19 PM
ITR764's Avatar
Default Re: Engine Dampner Kit (Splat)
why would our torqueless(sp) engines need one of these??
Old Dec 29, 2002 | 03:14 PM
Default Re: Engine Dampner Kit (ITR764)
Have you ever put your car on a dyno and watched the engine move?
Have you ever experienced the wheels skip and jump on the pavement under WOT in 1st gear?
Have you ever experienced sluggish response due to the engine not responding as immediate as it should when you hit the accelerator?
.......apparently not.....
Old Dec 29, 2002 | 03:17 PM
ITR764's Avatar
i have and that little thing is going to help that. that's allot of moving parts for that thing to stop.
i think a little less tone would be ok, this is a discussion and not a match as to how thinks they know more.
Old Dec 29, 2002 | 03:25 PM
apologies for coming off harsh...
share what you have in mind...
all I do know is the DC2 app. is not gonna work unless the piece you have designed is intended for the 6th gen hatch...or maybe something better for the DC2?
turbotime
Aug 10, 2006 03:10 PM
Tyson
13
Dec 24, 2003 10:25 PM
Ideal R
Apr 1, 2003 07:25 PM
paulITR
Jan 28, 2003 07:20 PM
GsR HtCh
Aug 18, 2002 10:11 AM
