Head gasket for minime swap
Hey, quick question, I have my stock y7 block, and i have a z6 head and im about to do my swap, i bought a head gasket from honda but i believe its for my y7, my brother believes the head gaskets are all interchangeable but we want to make sure. So do i need a z6 gasket, a y7 gasket or are they all the same? Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Get a Y8 2-layer gasket and have higher compression.</TD></TR></TABLE>
Im just wondering if i NEED to buy a new gasket, i already bought a y7 gasket, if i can use it i will but if i HAVE to use a y8 or z6 gasket ill have to go buy one, but im worried honda will not have them in stock...
i havent done anything yet, all i did was buy a y7 gasket... i want to know before i do anything if itll fit... but i think ill end up just going with a y8
I could have sworn the z6 and y8 headgaskets are the same. I can't see any problems with using a b7 headgasket besides the lower compresson. If you do get the z6 or y8 head gasket, take some pictures and compare the two. I used a z6 headgasket on my mini-me swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">All d-series head gaskets are compatible, so yes the y7 will work</TD></TR></TABLE>
Never knew that... thnx! Might just go with the y8 for the higher compression, and its cheaper than a z6, and yeah everyone says the y8/z6 are the same with different part #'s and different prices (z6 being about $20-30 more), but i hear the y8 is 2 layer and the z6 is 3... ?
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz »</TD></TR><TR><TD CLASS="quote">the y8 head gasket is a 3 layer. just remove the middle layer and you got a two later.</TD></TR></TABLE>WTF!!! Why would you do that? Think about layers in a headgasket as layers of naked ***** all over you. The more the better (to an extent with the HG though)... Put 1-2ft-lbs more torque on the bolts than the factory service manual states. I would actually even use some fine grit sand paper and polish up the mating surface a little bit. The cleaner and smoother the surface the better the seal on the HG.. Good luck and Happy Tuning!!
ej1 rep
Dec 22, 2011 09:21 AM
haroldthefly91crx
Aug 14, 2006 08:26 PM
Wes90civic
Jan 19, 2004 11:13 PM
