tranny leaking tranny oil
Old Apr 29, 2005 | 09:45 AM
komat's Avatar
Default tranny leaking tranny oil
i notice my tranny is leaking oil at the bottem
can i just use jb weld and cover it or would i need to pull the casing out and reseal it with some gasket sealment
Old Apr 29, 2005 | 09:58 AM
AutoXer's Avatar
Default Re: tranny leaking tranny oil (komat)
Is it a crack in the housing? Where exactly is it leaking from?
komat's Avatar
Default Re: tranny leaking tranny oil (AutoXer)
i dont see any crack
its leaking where the gasket is at
also a integra flywheel will fit any b motor right?
Old Apr 29, 2005 | 09:59 AM
Deemeetree's Avatar
Electrician
Auto or Manual?
Old Apr 29, 2005 | 10:00 AM
fasthatchb18c1's Avatar
you can take it apart and use some liquid gasket cause if you JB weld it will be a bitch to take it apart agian
Old Apr 29, 2005 | 10:04 AM
komat's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Auto or Manual?</TD></TR></TABLE>
manual
Old Apr 29, 2005 | 10:13 AM
AutoXer's Avatar
&gt;&gt;&gt;&gt;its leaking where the gasket is at
Then do not JB weld it. You will never be able to get it apart afterwords.
Old Apr 29, 2005 | 02:28 PM
komat's Avatar
does anyone know if theres enough space to put liquid gasket on the tranny casing without removing hte snap ring
Old Apr 29, 2005 | 02:58 PM
yeah you could try that but you would have to go all the may around which would be a bitch when a snap ring is pretty easy to open and Im not sure but I dont think it would be that good if any of the excess liquid gasket was floating around your tanny
EG2Driver
Nov 1, 2006 07:23 PM
h22pwr
Jan 7, 2006 04:46 PM
civiccrazy93
Nov 1, 2004 07:36 PM
integraGSR213
Feb 16, 2004 04:54 PM
serious
Aug 24, 2002 12:50 AM
