Installing Blox type B check valve
Old Apr 29, 2005 | 03:51 AM
88crxhfb16's Avatar
Default Installing Blox type B check valve
Has anybody installed a Blox type B check valve (does the same thing as missing link) on a 88 CRX. IT's the one that has the map sensor on the fire wall. I'm guessing that you just install it in line with vacumm hose leading to the MAP. with the Airflow going towards the Map or the Intake? and how close to the MAP?
thanks
Old Apr 29, 2005 | 06:55 AM
dr_latino999's Avatar
Default Re: Installing Blox type B check valve (88crxhfb16)
Airflow going to the MAP and wherever you want along the line.
Old Apr 29, 2005 | 07:30 AM
88crxhfb16's Avatar
Default Re: Installing Blox type B check valve (dr_latino999)
thanks that's what I figured
fabmaster
Apr 12, 2010 04:44 PM
h22sedan
Apr 3, 2007 09:30 AM
Visionist
Apr 27, 2006 09:02 PM
Mr.NiceGuy
Apr 9, 2002 02:36 PM
