Car bogging at low speeds.
quick question...had a bad radiator hose leak, coolant got onto the distributor cap...could this have fucked up the distributor and causing this weird bogging i'm getting? do i need to replace the distributor?
ok is it low speeds in higher gear and low rpm's too??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorcalHB94 »</TD></TR><TR><TD CLASS="quote">coolant got onto the distributor cap...could this have fucked up the distributor and causing this weird bogging i'm getting?</TD></TR></TABLE>
if it did screw it up it would most likely affect the car running at all even at idle
is there moisture inside the distributor??
why do people make a thread and then log off??
Modified by civictildeath at 2:07 AM 4/29/2005
LilCivic04
12
Oct 13, 2005 01:29 AM
IntegD
Apr 2, 2004 10:16 AM
