Seized bolt on Brake Caliper
Old Apr 28, 2005 | 04:59 PM
Hatch1990SI's Avatar
Default Seized bolt on Brake Caliper
Ive used brake cleaner, wd40, and a d-mn hammer, and yes, a 17mm socket. any ideas on how to get it off, the 2 bolts on the back of the brake caliper on a 90 civic si hatch. Anything other then torching it... thanks
Old Apr 28, 2005 | 05:07 PM
dr_latino999's Avatar
Default Re: Seized bolt on Brake Caliper (Hatch1990SI)
Are they the bolts attaching the caliper to the bracket? If it is, break out an impact and some PB blaster.
Old Apr 28, 2005 | 06:54 PM
Default Re: Seized bolt on Brake Caliper (dr_latino999)
It's the bolts holding the caliper onto the rotor.
Old Apr 28, 2005 | 06:57 PM
HatchBox's Avatar
Skoobie no more...
Heat them up carefully, dont melt the little plastic boot.
Old Apr 28, 2005 | 07:01 PM
B2FiNiTY's Avatar
Take it to a shop to impact it off and then hand tighten it.
Old Apr 28, 2005 | 07:15 PM
Autoworks's Avatar
Default Re: Seized bolt on Brake Caliper (B2FiNiTY)
Get some liquid wrench, spray it on, tap on it a little bit. Then try taking it off in a few minutes. Liquid wrench works alot better.
Old Apr 28, 2005 | 07:32 PM
eda6's Avatar
Default Re: Seized bolt on Brake Caliper (Autoworks)
36" breaker bar and nuts off
Old Apr 28, 2005 | 07:43 PM
bagpipe goatee's Avatar
for the 36" breaker, sounds good, but make sure you have a good quality socket that fits it tightly.
in my experience, the pb blaster works better for rusted stuff than liquid wrench
Old Apr 28, 2005 | 08:08 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (bagpipe goatee)
yeah use a 6 point socket instead of 12. 12 suck. good luck
RIMPR
Honda Civic (2006 - 2015)
May 23, 2015 06:05 PM
tommyofyork
Apr 6, 2007 01:53 PM
Deano_D aka "Brick Top"
14
Feb 21, 2005 12:37 PM
NoLipRacen
Mar 9, 2003 07:46 PM
Type Goch
Oct 13, 2001 05:17 PM
