windows wont roll up/down
Old Apr 28, 2005 | 04:31 PM
old-sk0ol's Avatar
Default windows wont roll up/down
i drive a del sol....my driver side window rolls up and down, but the passenger side and rear window wont
the fuses to them are not blown - other than faulty wires is there anything else that could make this happen??
Old Apr 28, 2005 | 04:33 PM
deserthonda's Avatar
chk to see if you have main switch on off
Old Apr 28, 2005 | 04:38 PM
ice11honda's Avatar
regulator gone bad would be my guess
Old Apr 28, 2005 | 10:47 PM
ikillradio's Avatar
maybe your window motor burnt out or you need to lube?
Old Apr 28, 2005 | 11:04 PM
Bond's Avatar
Default Re: (ikillradio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikillradio &raquo;</TD></TR><TR><TD CLASS="quote">maybe your window motor burnt out or you need to lube?</TD></TR></TABLE>
Having two burn out at once is pretty odd. Check main switch and wire connections.
Old Apr 29, 2005 | 05:41 AM
CivicEX96's Avatar
Default Re: windows wont roll up/down (old-sk0ol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old-sk0ol &raquo;</TD></TR><TR><TD CLASS="quote">i drive a del sol....my driver side window rolls up and down, but the passenger side and rear window wont
the fuses to them are not blown - other than faulty wires is there anything else that could make this happen??</TD></TR></TABLE>
broke or bent regulator, window slipped off tracks, dead window motor, silcone spray the rubber tracks because they are worn down...about all i can think of besides wiring, all of these i mentioned are common problems on civics...i have had a bent regulator once and had the window slipped off track twice even after spraying the tracks with silcone spray...not fun
n0rt0n
Jul 15, 2008 09:39 PM
stock99si
May 20, 2007 06:30 PM
EX-T
Dec 2, 2003 03:53 PM
h2392si
May 4, 2003 11:41 AM
iwhichisme
May 2, 2003 11:28 AM
