windows wont roll up/down
i drive a del sol....my driver side window rolls up and down, but the passenger side and rear window wont
the fuses to them are not blown - other than faulty wires is there anything else that could make this happen??
Re: (ikillradio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikillradio »</TD></TR><TR><TD CLASS="quote">maybe your window motor burnt out or you need to lube?</TD></TR></TABLE>
Having two burn out at once is pretty odd. Check main switch and wire connections.
Re: windows wont roll up/down (old-sk0ol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old-sk0ol »</TD></TR><TR><TD CLASS="quote">i drive a del sol....my driver side window rolls up and down, but the passenger side and rear window wont
the fuses to them are not blown - other than faulty wires is there anything else that could make this happen??</TD></TR></TABLE>
broke or bent regulator, window slipped off tracks, dead window motor, silcone spray the rubber tracks because they are worn down...about all i can think of besides wiring, all of these i mentioned are common problems on civics...i have had a bent regulator once and had the window slipped off track twice even after spraying the tracks with silcone spray...not fun
iwhichisme
05-02-2003 11:28 AM
