What gasket is this??
From: Where we rock teh dookies, Nor Cal, You Es of EY
I have a small coolent leak coming out of the the area between the block and the metal piece the bolts onto the block which the radiator hose connects too. It looks like a i need a new gasket, does anyone know what that gasket is?
Hopefully i made sense lol. Thans in advance!
It's not 12 for sure since the thing he speaks of is in front of the block where the top radiator hose connects to. I'm not sure if there is a gasket for it. The part is the water outlet cover. I dunno myself either.
Oh my bad i read wrong, i thought he said behind the block.
Maybe your hose is leaking, and need to replace that, because i dont think theres a gasket there either.
it is called a "upper water neck" and if u look close there is a gasket on it already so yes u should be able to get a replacment gasket
just go into auto zone and ask for a "upper water neck gasket"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
The water neck in question (there are two) is the one in the upper right hand corner of the picture here. It's probably a Hondabond liquid gasket. If you don't have Hondabond, you can use any kind of coolant-proof RTV silicone gasket maker stuff and you'll be fine.
</TD></TR></TABLE>The water neck in question (there are two) is the one in the upper right hand corner of the picture here. It's probably a Hondabond liquid gasket. If you don't have Hondabond, you can use any kind of coolant-proof RTV silicone gasket maker stuff and you'll be fine.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>It definitely is...
single_slam
Mar 5, 2012 10:20 AM
