How High Do You Rev Your Mild CRVTEC>>DID SEARCH>
Old Apr 28, 2005 | 06:48 AM
ek2k's Avatar
Default How High Do You Rev Your Mild CRVTEC>>DID SEARCH>
Just basiclly gathering some thoughts and inputs and again this is not for a stock block. i did search and found articles mostly on how high you can rev on a stock block with stock walls..
High high do you guys rev your crvtec on stock walls with custom or aftermarket pistons and rods?
How often do you guys do this? i.e. daily basis, racing only?
i know that the question must sound dumb if you are not making power after lets suppose 8k but, keeping in mind some of you out there are driving around untuned and haven't hit the dyno like me whats your thoughts..
please bump this for looking..-one
Old Apr 28, 2005 | 06:51 AM
ek2k's Avatar
Default Re: How High Do You Rev Your Mild CRVTEC>>DID SEARCH> (ek2k)
bump this b***!
Old Apr 28, 2005 | 08:57 AM
ek2k's Avatar
no input??
Old Apr 28, 2005 | 09:04 AM
chechin's Avatar
I'm building a CRVTEC and I planning on rev it not over 8.5k but I'll run with the CTR Cams, in a couple of months when I get more money I plan to buy some BC4's I think 8.8k must be the limit.
Old Apr 28, 2005 | 10:45 AM
ek2k's Avatar
Default Re: How High Do You Rev Your Mild CRVTEC>>DID SEARCH> (chechin)
thats cool, well i forget where is aw a post but someone said they reved to 9k at the most with aftermarket pistons and rods and stock walls... i was like damn
Old Apr 28, 2005 | 12:17 PM
SiRLudeVtec's Avatar
I didn't know the block had much to do with how high you can rev- i though it was the head - i.e. valves, springs, retainers - thats what i though - if you change to dual springs and titanium valves - you should be able to atleast rev to 10,000 - not saying that you're going to have power up that high, but still.....if you want power that high - you have to get some really nice cams....stage III
Old Apr 28, 2005 | 12:29 PM
ek2k's Avatar
Default Re: (SiRLudeVtec)
yes the the headwork is also part of reving that high but there is a particular reason for this thread because unlike all other b motors the b20 has thinner cylinder walls therefore making it wealer the higher you take it up. sure you can rev up high with a itr head or smoething but if you have a itr head on a b20 the you really have to balance the two and suppose if you have a stock block with a itr head the you really shouldnt be going over 8k....any more thoughts or more answers anyone.....how high can you rev up?
Old Apr 28, 2005 | 12:43 PM
VALET dude's Avatar
Default Re: (ek2k)
bump coz i wanna know too
Modified by JDMallmotaEG at 1:57 PM 4/28/2005
Old Apr 28, 2005 | 01:08 PM
getgot22's Avatar
Default Re: (JDMallmotaEG)
i rev my b20vtec to 8552 rpm to be exact..Fully balanced,stock rods, arp rod bolt a must.
Old Apr 28, 2005 | 02:04 PM
ek2k's Avatar
Default Re: (getgot22)
bump for more answers...
Old Apr 28, 2005 | 05:23 PM
MI4$DC5's Avatar
i thought a b20 wasnt ment to rev that high? Has something to do with the crank.im building mine and i plan on stopping at 8K myself.
Old Apr 28, 2005 | 08:36 PM
HBK GABE's Avatar
Default Re: (MI4DC2)
b20 stock walls can go to 9k fine with aftermarket rods and pistons, but don't do it all the time, as long as you don't boost or squeeze, the walls are fine.
Old Apr 28, 2005 | 08:52 PM
CRVTEC0WNZJ00's Avatar
Default Re: (626CivicSi)
Its tuning more than anything that cracks cylinder sleeves and inproper installation and just overall carelessness. With a really good tune you should be fine to rev to 9000rpm occasionally. Supposedly my engine will be fine to 9000rpm doubt I'll take it that high but supposedly it'll be fine that high and it was professionally built by the guy who builds Joe Demerys engines and he's got tons of experiece so everything is right. Heres my mods list though, you think this'll be safe to 9000rpm with a really good tune Hondata S200?
B20B4 Block Zyglowed, Bored & Honed to 84.5mm with Torque Plate, Align Honed, Hot Tanked, Surfaced & Decked
Crank Magnafluxed, Balanced, Micropolished
Clevite Rod Bearings
Clevite Main Bearings
ARP Head Studs
ARP Main Studs
ARP Rod Bolts
Eagle Rods 4340
JE Forged Pistons 11:0:1 Compression Ratio
ITR Water pump
ITR Oil pump
ITR Timing belt and new Belt Tensioner
Prodrive Oil Pump Gear
Golden Eagle LS/VTEC Conversion Piece
Endyn Crankcase Breather Kit
Cometic Head Gasket
2000 JDM ITR Cylinder Head
ARP Exhaust Studs
HP Racing 4-2-1 Stainless Header
AEBS Intake Manifold
RC Enginering 310 Injectors
STR 70mm Throttle Body
OBD1 GSR Distributor
Hondata Intake Manifold Gasket
AEM SRI Intake
ACT Streetlite Flywheel
AI4-HDR6 ACT 6 Puck Clutch
1996 ITR Transmission with LSD
Old Apr 29, 2005 | 05:36 AM
ek2k's Avatar
Default Re: (CRVTEC0WNZJ00)
looks and sounds good let me know how it goes and yes taking it to 9k is an occassional thing i think i will be taking mine to 8-85 on a daily basis...
Old Apr 29, 2005 | 09:40 AM
ek2k's Avatar
bump
Old Apr 29, 2005 | 01:11 PM
Eclypz's Avatar
my fuel cut is set to 8500rpm (software), but i shift at 8K.
On the dyno, i was taking it up to 8800rpm for about 21 runs, so i know it makes power up there, but i'm keeping it safe and shifting at 8K.
Old Apr 29, 2005 | 01:26 PM
MI4$DC5's Avatar
could i take mine to 8500 with stock rods with arp rod bolts?
Old Apr 29, 2005 | 02:34 PM
ek2k's Avatar
you could but i wouldnt do it if you have a stock block with just arp rod bolts thats just insuring you till about 8k anything more is in the i dont know zone.. so keep it at 8 cause those rods are skinny for the pistons... just my .02
Old Apr 29, 2005 | 02:35 PM
chechin's Avatar
at least shot peen your rods
ANVIL
K Series
13
Apr 8, 2013 07:08 PM
175Shot4Door
Aug 22, 2006 07:44 PM
type B16
Aug 20, 2006 11:41 AM
littlegreenb18
13
May 26, 2006 01:08 PM
thedirty-Dseries
Apr 18, 2006 07:16 PM
