what size injectors?
Old Apr 27, 2005 | 11:38 PM
99skunkedSi's Avatar
Default what size injectors?
i'm currently building my motor and not sure which size inj. to use.
Block:
gsr bored .25
arias pistons 12.5:1 custom
eagle rods
lightened balanced crank
Head:
b16 mild p&p
sk2 s&r
sk2 st2 cams
c/r will be @ 11.9:1 and i'm not sure which size inj. to use, rc310's or rc440's. can anyone give me some input on what they suggest. thx
Old Apr 28, 2005 | 04:16 AM
LSVTEC 91 Civic's Avatar
Banned
I think a set of OBD1 Prelude injectors (340cc) would work great for your setup...
Old Apr 28, 2005 | 05:56 PM
Default Re: (LSVTEC 91 Civic)
i never even thought of that! thanks man that's another thought
Old Apr 28, 2005 | 06:29 PM
chechin's Avatar
I thought the prelude injectors were 310cc...
Old Apr 28, 2005 | 09:08 PM
EG92's Avatar
Default Re: what size injectors? (99skunkedSi)
I'm running close to the exact same setup except I'm using a b20z block (stock bore) with 12.5:1 custom Arias pistons. I was able to put down 204whp on a dynojet using RC 310cc injectors. hope that helps
Old Apr 28, 2005 | 11:05 PM
k00lt1nt's Avatar
310 would be good enough...FPR also helps a heep also..
(((TIIIIITTTTTTTEEEEEEEEEEEE))))!!
butters's Avatar
Default Re: what size injectors? (EG92)
rc 310's will be enough.
Old Apr 28, 2005 | 11:08 PM
Vtec[Power]'s Avatar
JDM H22A 310cc is ur choice!
Old May 1, 2005 | 02:09 PM
Default Re: (Vtec[Power])
thanks for all the replies that is probably the size i'll use
Old May 1, 2005 | 05:07 PM
babietuan323's Avatar
310s would be sufficient enough goodluck
central_driver
10
Feb 18, 2009 09:33 PM
cyrix12
Dec 2, 2005 10:42 AM
Hoosier Daddy
Dec 9, 2003 10:35 PM
hondaspeder
Jun 22, 2003 03:06 PM
bikeboy80
Sep 18, 2002 02:24 PM
