Difference in B18b1's
90-93 B18b1s and 94+ b18b1's whats the difference.. everyone said to go with the 90-93 b18b1.. why..?? i heared the 90-93 block was built stronger to handle high compression?
The B18A and B18B bottom ends are identical. Neither is stronger than the other. On the other hand, the B18B has a better head and intake manifold.
iono i got all the info on the b18's on this engine spec site.. yehh.. umm 90-93 b18b1 has 130 hp and 121 torque and 94+ has 142 hp and 127 torque.. iono people keep tellin me the 90 - 93 is built stronger?
Most people probably told you go to with the 90-93 b18A1 because the 90-91 motors were obd0 and a lot simpler (wiring wise) to install into an EF/ED chassis.
Like storminmatt said, the difference between the b18A1 and the B18B1 is in the head/intake manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyboiWONDER »</TD></TR><TR><TD CLASS="quote">iono i got all the info on the b18's on this engine spec site.. yehh.. umm 90-93 b18b1 has 130 hp and 121 torque and 94+ has 142 hp and 127 torque.. iono people keep tellin me the 90 - 93 is built stronger?</TD></TR></TABLE>
There was no B18B1 made prior to 94, so you must be talking about a B18a.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">In 92-93 they changed the cams to my knowledge, but still had the same head casting as the prior years.</TD></TR></TABLE>
Th head casting changed for 1994.
'90-91 B18A1 (pre-OBD) - 130hp, 121 lb-ft, short-geared trans
'92-93 B18A1 (OBD-1) - 140hp, 126 lb-ft, long-geared trans
'94-95 B18B1 (OBD-1) - 142hp, 127 lb-ft, long-geared trans
'96-01 B18B1 (OBD-2) - 140hp, 124 lb-ft, long-geared trans
spencedogg
10
Oct 27, 2003 06:33 PM
