Crankcase evacuation (not a catchcan question)
Old Apr 27, 2005 | 07:17 PM
maxspeedhonda's Avatar
Default Crankcase evacuation (not a catchcan question)
Okay, this is one of the few things I need to wrap up on the car still. I have the moroso vented catch can hooked up now as per the supplied directions. I have three vents on my valvecover that need to term into something per nhra rules. I have been running them to the atmosphere for the time being. I have a 3 inch side bumper exit exhaust and I was wondering if I could just run the three lines into the exhaust without using the summit kit for the v8 motors. Alll the vents are behind the valve cover baffeling, so I don't think oil is going to get sucked out. I am concering about exhaust getting pushed back into the motor. I really have little to no backpressure as it stands right now.
Old Apr 27, 2005 | 07:32 PM
DaveF's Avatar
Default Re: Crankcase evacuation (maxspeedhonda)
those things that they weld into the exhuast, i belive are check valves, also, the exhaust will create a vacum effect, and help scavenge the crankcase pressure.
Old Apr 27, 2005 | 08:50 PM
HondaTechIsTheGay's Avatar
Default Re: Crankcase evacuation (Dturbocivic)
Yep, I only know one person who has done it..
Old Apr 27, 2005 | 10:07 PM
V-SPEC 1's Avatar
do you have pics of these valve cover w/ 3 vents? i like to see them. thanks.
Old Apr 28, 2005 | 04:01 AM
Default Re: Crankcase evacuation (V-SPEC 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">do you have pics of these valve cover w/ 3 vents? i like to see them. thanks.</TD></TR></TABLE>
Yeah, I'll get a pic uploaded after work. I am using rubber fuel hose with pipe fittings now temporary, but I'm getting the alum. fittings welded in this weekend with the braided lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">those things that they weld into the exhuast, i belive are check valves, also, the exhaust will create a vacum effect, and help scavenge the crankcase pressure.</TD></TR></TABLE>
The pieces that actually weld into the exhaust aren't check valves. They are just angle cut pieces of pipe that create the vaccum effect. You are supposed to put the check valve that comes with the kit between the piece that welds into the exhaust and the valve cover. I was just wondering if I could just run three lines directly into the exhaust using an angled piece of pipe with having to buy the kit with the check valves. Do you think that my car is actaully going to make enough backpressure with a 2 foot exhuast to cause a problem? Keep in mind, that this car will only be track driven.
Old Apr 28, 2005 | 04:58 AM
DaveF's Avatar
i suppose if your engine speeds weren't high. the speed of the exhuast traveling through the pipe, couldnt create a big enough vacum effect and the exhuast could find its way into the "crankcase" .....
Old Apr 28, 2005 | 07:24 AM
fast is fun's Avatar
use the check valves they work and will pull vacum on crankcase witch makes HP
v8 boys have it for years !!!
SPoole
Jul 20, 2008 01:57 PM
Mr HYDE
Jan 9, 2007 07:48 PM
94lsboost
Feb 3, 2005 09:08 AM
cal_
Nov 17, 2004 07:25 PM
niedejb
Aug 25, 2002 01:32 PM
