Will these still work?
I just bought these headers, and the kid said all u had to do was weld on a new flange, cause for some reason it was cut off... But yea, can i still use these with a new welded on flange?
Of course you can. Get a new flange from a junked header or get one from a local parts strore. Make sure it's the same bolt pattern on the flange. Plus, make sure it's welded properly so it will line up perfectly.
Ok cool, im goin to an exhaust shop tomorrow to have them weld on a flange, and if i have to, add a test pipe or something. After asking a few people, they werent sure if it was stll usable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v0lcom27 »</TD></TR><TR><TD CLASS="quote">Anymore second opinions?</TD></TR></TABLE>
Welding > You.
Welding > You.
You would need to weld it so it uses a donut and connects like stock, otherwise, when the motor torques, you might break the studs on the head or something. Or you could just a flex pipe.
nyckid
10
Dec 22, 2015 09:04 AM
socalismylife
Welding / Fabrication
20
Jan 9, 2008 07:45 AM
9civic8
10
Oct 15, 2005 06:51 PM
