CLutch Gone??!!!
I think my clutch is gone i try to start my car and i have to put sooooo much pressure on it like against the floor just to get it started and i have to do that about 7 times before it works and i have to hold it if i move a little it wont even try to turn over.im not positive but i think its gone....if so im gonna go ahead and get a new tranny,clutch,and flywheel.(i have a shitty 4spd still)
isn't there a switch on the end of the pedal that allows the car to start...
like when the clutch is not in it won't start, but once the clutch is pressed it completes the circuit and allows the car to start.
once the car is started can you go through the gears okay? is the clutch slipping?
more info about while the car is running....
well i tightened my clutch cable and now i can shift into gears perfectly but like i said i still have to give my clutch excessive pressure when trying to start and it usually takes me about 5 trys before i get it in the right spot then BOOM it starts up. WTF is the problem???
If you have to give excess pressure while starting, go and check your actual assembly. I had this same problem in December and it turned out I had actually broken the clutch pedal where it pivots
look at your actual clutch pedal assembly check the rod that goes from the break pedal to the clutch pedal. Its a shitty rod that is spot welded and always breaks. I have broken 2 clutch pedal assemblys and if this is your problem i would highly sugest replacing the cable as well cause i stretched mine by adjusting it everytime my car wouldn't start
LMFAO!!!! this is the exact problem, Clutch peddle assembly. I have been doing the tightening trick to it everytime, and im sure its fucked now....did it feel like your car shifted into gears, almost better when u tightened your clutch cable? and did it get worse and worse til it just wouldnt work anymore?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90HcDxR »</TD></TR><TR><TD CLASS="quote">has this happened to anyone else before?</TD></TR></TABLE>
Me, 2KTeg, You apparently, Dosvita, CRX Toad, redzcstandardhatch, Tireneck, etc..
haha thats exactlly what happened i noticed that bar thingy looking crooked but even if that broke why would it cause me to not be able to start my car??
if you get another stock one have it welded up because it will just break again... its a nightmare to take them out.... i would take your seat out its easier to lay under the dash that way.. you have to drop the stearing colum and make sure you get the very top bolt under the air ducting...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90HcDxR »</TD></TR><TR><TD CLASS="quote">haha thats exactlly what happened i noticed that bar thingy looking crooked but even if that broke why would it cause me to not be able to start my car??
</TD></TR></TABLE> Because the clutch pedal can no longer touch the clutch switch, so it is like trying to turn on the car without touching the pedal. What happens, nothing
yea how much for the clutch? damn this sux, im broke and I am going to have to do this myself. hey dr.latino could u let me know the steps i would have to take to do this??
peacexisxfree
May 15, 2006 05:37 PM
99cpevtec
Jul 15, 2005 02:27 PM
