idle troubles... out of ideas someone help
Old Apr 27, 2005 | 02:32 PM
pK1spooled's Avatar
Default idle troubles... out of ideas someone help
Hey everyone, ive been trying to troubleshoot my retarded idle for awhile now and im just about out of ideas. To start, ive got an ls/vtec setup, gsr head, and JG intake manifold. It idles at ~1500rpm, and surges sometimes, but not often. I found out the IAC was leaking, so I tried every sealent out there and I changed the o-ring for a new one. Same problem. Ive sprayed the entire intake area with intake cleaner and cant seem to find any other leaks. Ive adjusted the idle screw and it doesnt help. What am I missing?
thanx
Old Apr 27, 2005 | 02:34 PM
pK1spooled's Avatar
Default Re: idle troubles... out of ideas someone help (pK1spooled)
and I also tried a P72 and chipped P28 ecu, no difference.
Old Apr 27, 2005 | 07:18 PM
drives a vtec's Avatar
Did you try replacign the IAC itself, the motor will fail without setting a CEL, same problem I had, swapped to another one, problem went right away. . .
Of course after I put the intake manifold gasket on and throttle body chasing the motor the whole time
Old Apr 27, 2005 | 10:55 PM
PrettyLude's Avatar
it could be a number of things:
bubbles in your coolant
iacv
fitv
vaccuum leaks
andybmuzik
Aug 9, 2013 08:23 PM
ctr status
Mar 2, 2009 08:11 PM
mfzbike
Apr 24, 2008 06:50 PM
90crxdriver
Jun 24, 2007 03:32 AM
STUCKED
Mar 1, 2005 12:52 PM
