Rough idle only when hot
Old Apr 20, 2008 | 02:16 PM
mfzbike's Avatar
Default Rough idle only when hot
Setup:
built 18c1
b16 head
1000cc msd injectors
precision turbo @ 14pss
chipped ecu tuned with crome
blox intake manifold
torqued everything twice
no known vacuum leaks
cleaned iacv, then traded out with a known working iavc, same problem
just curious if something in particular "once at operating temp" that i'm missing.
Maybe intake manifold gasket cracked?
havn't tried coolant bleed, dont really think its that though..
would a retune possibly help??
its weird it only idles bad when its hot....
i know its just another idle thread, but i'm geting frustrated.
thanks guys
Old Apr 20, 2008 | 05:34 PM
Ej1ownzu's Avatar
I have almost the same set up but different intake mani and turbo! I have a wideband 02 and when it starts to idle rough it will start going lean (from 14.7 up to 19.6). I have changed everything you have listed + the intake mani gasket. I would like to know whats going on too! Please HELP us!!
Old Apr 20, 2008 | 06:33 PM
zex_cool's Avatar
hot as in IAT or ECT ? any power stuff on ? [heat,lights,break,etc] or does it not matter ?
Old Apr 20, 2008 | 06:52 PM
Garage 808 Hatch's Avatar
Default Re: (zex_cool)
we had a car do this same thing recently, it was a clogged injector. i dont know why it only acted up while hot, but these are EXACTLY the same symptoms
Old Apr 20, 2008 | 07:19 PM
Ej1ownzu's Avatar
Default Re: (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zex_cool &raquo;</TD></TR><TR><TD CLASS="quote">hot as in IAT or ECT ? any power stuff on ? [heat,lights,break,etc] or does it not matter ?
</TD></TR></TABLE> ECT and it doesnt matter whats on!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">we had a car do this same thing recently, it was a clogged injector. i dont know why it only acted up while hot, but these are EXACTLY the same symptoms</TD></TR></TABLE>
My injectors are new maybe 1500 miles now!
Old Apr 20, 2008 | 07:21 PM
Default Re: (Ej1ownzu)
so were the ones in this car. unedr 2k miles, new RC 550's
Old Apr 20, 2008 | 07:26 PM
Ej1ownzu's Avatar
So how do I go about cleaning them?
Old Apr 20, 2008 | 07:32 PM
We use a fuel injection shop/diesel shop they do flow tests and cleanings.
Old Apr 20, 2008 | 07:38 PM
Ej1ownzu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">We use a fuel injection shop/diesel shop they do flow tests and cleanings.</TD></TR></TABLE>
that didnt help answer my ??? Is there a different way to tell if the injector(s) is/are clogged?
Old Apr 20, 2008 | 07:43 PM
zex_cool's Avatar
reason i ask is because i had a similar issue. my was with the IAT though. when the engine would get heat soaked around 135* it would run like ***.
it was simple fix that i didnt know about. at 135* in eCtune and at 133* in CROME IAT correction retards 3degrees and makes the car run like ***.
Old Apr 21, 2008 | 09:05 AM
mfzbike's Avatar
well i guess i'll try cleaning the injectors!
Old Apr 24, 2008 | 06:50 PM
Ej1ownzu's Avatar
Default Re: (mfzbike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mfzbike &raquo;</TD></TR><TR><TD CLASS="quote">well i guess i'll try cleaning the injectors!</TD></TR></TABLE>
well if that doesnt work, try a different alternator that fixed mine. It wouldnt change at idle!!
93SiPrelude
Feb 24, 2008 10:39 PM
civic92si
Apr 14, 2007 09:35 PM
Hella_Fresh
Apr 3, 2007 08:11 PM
Out of every "game"
Feb 8, 2006 01:12 PM
98itr0448
Jul 10, 2004 03:17 PM
