gauge type, which is better, mechanical or electrical?
Old Feb 1, 2002 | 06:54 AM
gsr98vtec's Avatar
Default gauge type, which is better, mechanical or electrical?
going to get some autometer gauges, i know they are not the best, but they serve their purpose. which type is better though?
Old Feb 1, 2002 | 07:17 AM
sgT's Avatar
sgT
Default Re: gauge type, which is better, mechanical or electrical? (gsr98vtec)
electrical
Old Feb 1, 2002 | 07:19 AM
HX_Guy's Avatar
Default Re: gauge type, which is better, mechanical or electrical? (sgT)
electrical
Reason?
Old Feb 1, 2002 | 07:21 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
electrical
Mech. is more accurate in my experience. (well reads higher for oil and water temp from the same pickup point.. so I guess I'm assuming). Electrical is easier to install though.
Old Feb 1, 2002 | 07:22 AM
austrian type-R's Avatar
Default Re: gauge type, which is better, mechanical or electrical? (HX_Guy)
I would say for fuel get an electrical and for boost a mechanical one (it is better cause it is simplier and work as accurate than the electrical one)
Old Feb 1, 2002 | 07:24 AM
Sleeper's Avatar
Safety? No fuel or oil lines going into the car.
Old Feb 1, 2002 | 07:25 AM
sgT's Avatar
sgT
reason = easier to install.
autometer mechanical temp gauges are a bitch,
though for oil pressure and fuel pressure i only use mechanical
b00st-0wnz's Avatar
Default Re: gauge type, which is better, mechanical or electrical? (Sleeper)
I see you have a LOT of experience with these gauges. lol!
Old Feb 1, 2002 | 07:26 AM
HX_Guy's Avatar
Do you have these going into the cabin?
Old Feb 1, 2002 | 07:29 AM
sgT's Avatar
sgT
oil pres yes
fuel,no
Sleeper's Avatar
Default Re: gauge type, which is better, mechanical or electrical? (Dave-ROR)
What do you mean? I have Autometer electric oil and fuel pressure guages. I've heard of some installing mechanical incar. Why would you run a live fuel or oil line into the passenger compartment for a gauge? I think that a few quarts of either on your floorboard would change your mind.
[Modified by Sleeper, 4:47 PM 2/1/2002]
Old Feb 1, 2002 | 07:32 AM
b00st-0wnz's Avatar
That's my point. You don't. You don't run a oil line in and out. They use a seperate line with a fluid in it which the gauge reads. The oil never comes to the gauge. (fuel neither, at least not on the one we have)
[Modified by Dave-ROR, 11:32 AM 2/1/2002]
Old Feb 1, 2002 | 07:35 AM
sgT's Avatar
sgT
i dont use an isolator because i havent seen a 100psi isolator yet.
the carburator ones(0-15psi) WILL break.
I just run oil to the gauge. It doesnt leak and doesnt cause any problems.
Much better than the electrical oil pressure gauges i;ve had
Old Feb 1, 2002 | 07:39 AM
b00st-0wnz's Avatar
We don't run oil/fuel to either gauge.. it is a carb'd car though (explains the iso part). But even for oil we don't, but I would doubt there'd be a problem either way.
Old Feb 1, 2002 | 08:02 AM
gsr98vtec's Avatar
ok i want to get a oil pressure, oil temp, and water temp gauge
which style should i buy of each, seems oil pressure people lean toward mechanical.
also will i have to tap my block for the oil pressure or temp?
Old Feb 1, 2002 | 08:05 AM
sgT's Avatar
sgT
pressure comes from where the current pressure switch is on the back of the
block. the temp sender should be installed in the oil pan
Old Feb 1, 2002 | 08:11 AM
gsr98vtec's Avatar
do you just weld the oil temp sensor into the oil pan?
the water temp gauge just uses the stock connection right?
Old Feb 1, 2002 | 08:15 AM
sgT's Avatar
sgT
you weld a fitting and put the sender in that.
water temp neds its own sender mounted in a water hose somewhere.
I mounted mine in the radiator neck on the head.
it cant use the stock sender because the outputs are different
Old Feb 1, 2002 | 09:05 AM
gsr98vtec's Avatar
cool, well time to get to work then
97dc2
May 24, 2005 03:36 PM
JSR3STS
Feb 9, 2003 05:21 PM
pagong
Dec 23, 2002 08:48 PM
iH8RICERZ
Nov 25, 2002 03:02 PM
IntegraR0064
Jul 2, 2001 09:08 PM
