Installing cams...
Old Apr 27, 2005 | 07:43 AM
hotdoggies's Avatar
Default Installing cams...
Hey guys i need to know if i will need itr camgears with the itr cams iam throwing in my car this weekend or if i can just use the stock b-16 camgears???????? Also how complicated is this process and what should the valve lash and all the other stuff be set at?
Old Apr 27, 2005 | 07:47 AM
Deemeetree's Avatar
Electrician
From the sound of it, get a Helms manual.
Old Apr 27, 2005 | 07:49 AM
hotdoggies's Avatar
Default Re: (Dimi)
You are probally right But could i use the stock b-16 cam gears with the itr cam????
Old Apr 27, 2005 | 07:58 AM
Deemeetree's Avatar
Electrician
To get any power out of those cams on a B16A, you'll definitely need to get adjustable cams and get it tuned.
Old Apr 27, 2005 | 08:05 AM
Luserkid's Avatar
Default Re: (Dimi)
Honestly seeing as your a DOHC if you dont know what your doing dont do it at all, until you get a good manual from somewhere. Its real easy to mess this up.
Also if you dont have air then those cam gears are going to be fun to take off.
Old Apr 27, 2005 | 08:13 AM
JDMSiGuy17's Avatar
Default Re: (Luserkid)
yeah from the sounds of it, it doesnt sound like your ready to take this on yet. if your timing is off by even one tooth it could be bad news for you. but if you do decide to do this yourself i would make sure you have the helms manual, air gun shims, tourqe wrench, and make sure the motor is cold. and just to save on labor i would get the gears now so you dont have to do this all over again. but good luck!
Old Apr 27, 2005 | 08:46 AM
blackeg's Avatar
Default Re: (JDMSiGuy17)
b series adjustable cam gears are the same, at least for the vtec's. i would triple check on this though, because if your timing is off, byebye valves
Old Apr 27, 2005 | 10:15 AM
Quiks66's Avatar
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Honestly seeing as your a DOHC if you dont know what your doing dont do it at all, until you get a good manual from somewhere. Its real easy to mess this up.
Also if you dont have air then those cam gears are going to be fun to take off. </TD></TR></TABLE>
Word. DO NOT DO THIS UNLESS YOU KNOW WHAT YOU ARE GETTING YOURSELF INTO. It's much easier to mess up than you think. Make sure you get the proper tools, manual, and have someone there who has done it before. Good luck.
turbodailydan
Jan 21, 2010 06:12 PM
steve00si
Oct 20, 2005 07:39 PM
boostedbseries2000
Jan 2, 2005 04:21 AM
cr00klyn718
Mar 5, 2002 11:34 PM
